Quote Originally Posted by paolorenzo View Post
140kms with the last light blinking?!
You got a SGI kit from GreenFuel? I think it's in the programming. In your case, it probably blinks too early. With 140kms, parang half-tank pa yan.
Sa akin mga 220kms ang 47 liters. So pag-nag-blink na, I wouldn't want to drive it for more than 20kms. Pero di pa naman ako nauubusan ng LPG. The EROOM switch as 5 LED lights - red "E", 3 green, and another green "F". Yung red "E" (empty) LED yung nag-b-blink after a while. I have the standard 66-liter cylidrical tank, 50 liters ang max na na-load ko so far.
That's correct, it is still half tank. I have it confirmed last time when I do refill.
I have it reprogrammed couple of times but still could not have it perfectly done. It may be due to my toroidal tank orientation that is not standard pointing 6 o' clock. Mine is somewhat oriented at 5 o' clock getting the orientation from my fabricated rigid tank cage/support bolted on the chassis.
