hello sa lahat.... bago lng ako d2 pero palagi ako nag babasa ng forum d2 nakakatulong sakin ang forum na to pero sa pag kakataon... na ito baka may ma share ako d2. yan design na pinakita ni Mr. Ghosthunter ay tinatawag na smack booster. it is a electrolysis method na seseparate ang 2hydrogen ang 1 oxygen pero ang result at 2HO or HHO pero. ito at dalikado pag nag backfire yung engine ninyo sasabog yung smackbooster. kasi in the trianglular rules of fire there's a 3 needed (fuel, oxygen and ignition) to produce fire or explotion the smackbooster has 2Hydrogen gas and 1 Oxygen Gas. means ignition nalang sabog na. Pero may solution dyan para pure hydrogen ang ma gets mo sa electrolysis mo kasi ang hydrogen from water goes to negative side and Oxygen to positive yan ang solution to separate hydrogen and oxygen kelagan 2 chambers ang electrolysis mo to prevent fire. Hydrogen cant explode without oxygen.the chambers of negative(hydrogen) and the other is positive(Oxygen) at 15amps at 12volts (references) http://www.instructables.com/id/Sepa...er-Through-El/ yan na po sana maka tulong ako para sa atin lahat.... accually I make One of this electrolysis soon
You are missing the point of using a electrolysis cell similar to the Archie Blue design. It is very compact hence very useful if you have very limited space to use. The potential of a backfire can be minimized by using flame arrester screens.
Designing an electrolysis cell with separate storage for the H2 and O2 is basic elementary chemistry. Unfortunately it will take too much space and it can be inefficient in power vs volume of gas generated. Granted you can add a salt to increase production, it will also increase the corrosion rate of the electrodes.
in my opinion, adding tiny amounts of hydrogen (or acetone..) to enhance combustion efficiency is the wrong way to go about it.
the "right" way to go about it is dual spark plugs. oh wait, honda already does that in their 1.3 i-DSI engine. :P
Methods differ depending on what you are targeting or aiming for.Originally Posted by orly_andico
Hydrogen is meant to offset the fuel used. Hydrogen is proven to be a possible replacement for gasoline. The only problem is to produce hydrogen in an economical way.
Acetone mixed in gasoline is meant to change the surface tension of gasoline which would (hopefully) increase the combustion efficiency by providing better (smaller) atomized size of gasoline.
There is no right or wrong way as long as the targetted aims are reached without negative effects (like increased emissions of pollutants, excessive cost of technology passed onto consumers, etc).the "right" way to go about it is dual spark plugs. oh wait, honda already does that in their 1.3 i-DSI engine.
BTW, Honda wasn't the first to do dual sparkplugs in their engines. Mazda already did it much earlier.
