Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Jun 2008
    saan ba pwedeng magpalagay ng alcohol water injection.
    di ba nakakasira ng makina to kze hinahaluan ng tubig ung cylinder di ba ito manganngalawang pls help
    thanks po
    Sep 2009
    Ang importante in vapor form ang alcohol at water when feeding it as fuel, that way, mas maganda ang mixing with air and your primary fuel. Point of entry is through a vacuum hose connected sa intake manifold and another on the air intake passage in front of the throttle plate.
    If you consider not using alcohol at all for lesser cost, maging mas malinis ang combustion chamber ng makina kung may halong water vapor ang intake charge na fuel-air mixture. You still have to balance your overall fuel-air-water mixture for better results.
    Quote Originally Posted by ryn12000 View Post
    thanks po
    Mar 2007
    Vernieg is right - as long as it is in vapor form - no harm for your engine.
    Try searching for Devildok in this website.. he installs water-alchohol injection kits.
    [SIZE="4"]REMINDER: do not post messages in SMS/TXT format.
    READ the RULES.
    [/SIZE]
    thanks po
    You might want to read this:
    Devilsown Alcohol Injection Event Results
    http://tsikot.yehey.com/forums/showthread.php?t=48442
    It will be ok just set a pressure not to low, 8psi pataas.
    Mabilis mag vaporize, baka sa intercooler palang naging gas form na.
    SPEEDLAB sells Devil's Own alcohol/water injection kits.
    You can call to inquire to price and availability of kit types to fit your vehicle.
    Website and contact info: http://www.speedlab.com.ph/
    Dec 2007
    Quote Originally Posted by ehnriko View Post
    I actually am the founder of Devilsown alcohol injection, But yes check with Speedlab in QC, they have our newest kits in stock and are know all about the in's and outs of running the system.
    Jun 2008
    pumapasok ung condensed water sa cylinder di po ba ito mag cost ng kalawang or other problem sa engine gusto ko kze sanang magpalagay sa ford everest ko pero research muna para sure . and anong alcohol ang pwedeng ilagay
    The "research" you are looking for is just a click away by clicking the link to the DevilsOwn thread posted above.
    BTW, alcohol/water injection works best if the vehicle has some sort of forced induction (turbo, supercharger). Normally aspirated engines don't gain as much power.
    As for water causing rust, won't happen because the system will only trigger when the engine is running under heavy load or similar. The system will not trigger at idle.
    Also the devilsown kit atomizes the water. That means no condensations, etc.
    As for the alcohol type, any will do. Rubbing alcohol, methanol, ethanol, ethyl alcohol, vodka, etc. Of course performance will vary depending what you use.
    Sep 2009
    Last week sa auto repair shop ng kaibigan ko, may isang 1.3 toyota corolla, sira ang engine gasket, pumapasok ang tubig (coolant water, same water sa radiator) sa 2nd cylinder. The owner was surprised na visually malinis ang piston crown at buong cylinder (parang pinalitan ng bago), walang carbon deposits at walang rust. He even ask everyone sa shop kung sino ang nag linis sa second cylinder at piston nito and everyone told him "no one cleaned that cylinder and piston, it is already like that when we open your engine today". The rest of the cylinders have carbon deposits on the piston, makapal na nga parang asphalt concrete.
    Condensed water will not cause corrosion on the cylinder, may engine oil coating ang cylinder everytime madaanan ito ng piston.
    puymapasok ung condensed water sa cylinder di po ba ito mag cost ng kalawang or other problem sa engine gusto ko kze sanang magpalagay sa ford everest ko pero research muna para sure . and anong alcohol ang pwedeng ilagay
    Oct 2009
    ...anong alcohol ang pwedeng ilagay
    methanol or ethanol... whichever you can get cheap... lambanog will probably even work.
    Jun 2008
    thanks mga bro
    Jun 2008
    thanks bro
    Dec 2007
    If your vehicle is not forced inducted you would be better spending your money elsewhere unless it's highly modded and can be tuned, ie raise the timing to take advantage of the higher octane and reduced intake temps.
    Go with a highflow intake and exhaust would be a good start.
    Jun 2008
    wala bang magiging problema sa intercooler turbo itong alcohol injection ano bang disadvantages ng alcohol injection balak ko kze talagang magpalagay
    Jun 2008
    mag kaka conflict ba to sa intercooler turbo ano bang disadvantages ng alcohol injection thanks for help balak ko talagang magpalagay nito thanks a lot
    READ the RULES.
    [/SIZE]
    No problems with the intercooler.
    Only disadvantage is the water/alcohol supply is limited to the size of your container. So if you hit the "juice" a lot, your supply will get used up quickly.
    Mahal na price nila ngayon compared ng pagbili namin noon tapos ewan ko lang sa ibang nagpakabit ha, pero ang sa vehicle ko 8 months lang gumana at sira na agad ang pump. Di na ako nag claim ng warranty kasi ang hirap kausap speedlab. Ganon di problem ni Saberrider sa unit niya. Wish may iba pang dealer nito sa pinas. Sabi nila, the pump that they are using "will outlast your vehicle" pero sa unit ko hindi eh. Bihira ko pa gamitin sasakyan ko nyan ha since wala naman ako sa pinas palagi
alcohol water injection (help)
