Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    sir, kailangan ko po opinion nyo. Ano po ang mas ok para po sa inyo..
    A.) 1999 HONDA SIR PHP 320T
    79T mileage (orig)
    Manual Trans
    Cold Aircon
    newly replaced tie-rod, rack-end, stabilizer link, steering boot
    newly repainted
    circuit8 mags and 4 new tires
    Cons:
    no stereo, left ball joint needs to be replaced
    B.) 2005 Mazda3 PHP 380T
    60T orig mileage
    Tiptronic
    All stock
    HID headlight and foglight
    LCD monitor
    Sound setup
    Cons:
    No Aircon
    Needs repainted, daming gasgas
    Needs 4 new tires
    May shift shock (According from the owner normal lang daw ito)
    As is where is po ang price... Both are 2nd owned units.. Ano po pipiliin nyo considering 6 years ang gap ng MAZDA3.
    I like mazda3 kasi mas bago, pero thinking of the repairs needed make me very hesitant, plus i heard mas mahal daw ang parts ng M3 kaysa sa S.I.R.
    Thanks
    May 2007
    kung sariwa pa yung S.I.R., dun ako..
    mas mura ang stereo + balljoint kaysa dun sa papa ayos sa mazda3 plus you get 160hp stock.
    pero kung gusto mo ng mas bago na modelo tsaka kung may extra money ka, dun ka na sa mazda3
    your money, your decision.
    Nakakatakot naman yan mazda na yan bakit walang aircon? di kaya nalubog yan?
    Last edited by emms1121; October 19th, 2009 at 05:03 PM. Reason: cited stereo instead of aircon
    At 400K+ you can already find a Mazda 3 in good condition.
    Jun 2008
    '05 Mazda3 without A/C? Seriously, WTF?
    BTW, P300k flat (or a little less) sounds good for a decent SiR. But the keyword is decent.
    Jan 2009
    I agree with this, and the Mazda 3 is a very risky option. Sounds like a car nap or accident history to me.
    SIR pa rin, its a classic.
    M3 w/o Aircon.
    Go for the SIR atleast you have less problems to think of than of the 3's.......well atleast, for now.
    Yun din naisip ko, less gastos ang s.i.r... nagagandahan kasi ako sa itsura ng M3, pero takot ako baka daming pang aayusin...
    Sabi ng owner, freon lang daw kulang.. di ito nalubog sa baha, nor nabangga... I know it's history, The problem is, di talaga marunong mag-alaga ng kotse ang owner.
    Although loaded ang Mazda 3, will the 60 thousand price difference offset the repainting job, buying new tires, and airconditioning repair? Choose the better maintained car.
    Aug 2009
    for me i would settle for SiR, less expense compare sa Mazda3..baka nalubog sa baha yung masda3
    Oct 2005
    Definitely not the Civic for its already a decade old but not the Mazda as well. For a budget as high as 380K you can find a lot newer and more decently conditioned units.
    Jun 2008
    Raise your budget a bit more and get another Mazda.
    we have a 11 year old advie GLS at home. My dad uses it nalang. Yesterday, I used it service a bunch of people... daming tunog sa under chasis... Aircon is still cold pero its a decade old car... So I had it check by my mechanic (not my dad's)... assessed around 100T gastos max..
    Repainting job is 30T
    Replaced timing belt and so forth 15T
    Calibration 8T
    Replaced shock and ball joint, etc around 30T
    Replace aircon air vents
    So i told my dad its time to sell the old advie at 250t and get a new one at 850T... By being practical, my dad decided to keep the advie and have it repair na lang.. he said, better to spend 100T on repairs than wasting 600T on a new unit (which he argues the engine is practically the same)...
    May pahabol pa dad ko... pwede ba raw i-dress up ang advie kung gusto ko.. hahaha
    Tama po ba ang decision?
    Dudee,
    OT post mo. Anyway, sobrang mahal naman ng mga repair na ginawa..
    Sep 2008
    420k meron kanang matinong mazda 3...04 model..
    Quote Originally Posted by Dudee View Post
    Calibration 8T
    No. Papagawa niyo ng advie niyo, pero malay niyo after quite some time may sira nanaman edi ibang gastos ulit. Ganito na lang....
    Sell your advie then ; your budget doesn't need to be 850k, you could get an Adventure, AGAIN for a much lesser price. Or, settle for a sentra / vios which is around 595k ( vios ) and the sentra which is priced at 610k.
    Your dad's advice is the one I would follow. Unless you're buying a new car or a used one that you are familiar with in terms of condition and history, just repair the one you have now. You know the history of the Adventure because you own it already, the other cars that are used and you are not very sure of the history. Those problems you mentioned may just be the tip of the iceberg for those cars. I would bet the Mazda doesn't just need a recharge of the AC. How does a car only 4 years old already need a recharge of the AC? All the cars I have had have never needed a recharge in the first 5 years, and when it eventually needed a recharge it was because of a leak in the condenser or someplace else. The Honda could have an engine that's been put away wet and abused since owners of those cars like to use race those engines.
    Jul 2004
    Forget the Mazda 3, as you said, hindi marunong mag alaga yung owner. I'm sure aside from the problems you said, madami pang ibang mechanical or whatever problem na lalabas diyan. 60k kilometers of careless ownership, madame na magiging problem yan.
    What variant yung Mazda 3? 1.6S, V, HB or 2.0R?
    380k acquisition cost+cost of repairs siguro almost 500k magastos mo. Buy a well maintained Mazda 3 nalang. Same lang gastos mo, current price of M3 range from 400-500+ depending on they year model, mileage, etc.
    Quote Originally Posted by emms1121 View Post
    Dudee,
    Di pa po ginawa ang repairs, rough estimates pa lang yun.
1999 Honda SIR vs 2005 MAZDA3
