Results 1 to 13 of 13
    Jul 2006
    what are the pros and cons of a 96 honda civic vti?
    cons -- rusty roof
    stab link and trailing arm annual repalcement
    aircon produces foam like things lalo na kung bagong linis.
    water getting inside the trunk
    stuck up or very slow power windows sa likod.
    pros
    sarap driving experience
    matibay makina
    ganda porma
    you'll have no prob with power (if your not into racing)
    high resale value
    and most of all... vtec!
    Jan 2008
    kasama ba sa cons ng civic ang cooling system? i mean common ba sa civic ang over heating?
    with my experience... got a civic LXi 2000, wala naman po overheating. still midway ang temp ko. though im due for water pump replacement na. hirap na eh.
    Jul 2006
    Quote Originally Posted by enzo18 View Post
    matibay po makina ng honda. pero kahit anong sasakyan pag napabayaan e sigurado may chances na mag overheat.
    Jul 2006
    Quote Originally Posted by archie123456789 View Post
    1-rusty roof
    2-stab link and trailing arm annual repalcement
    3-aircon produces foam like things lalo na kung bagong linis.
    4-water getting inside the trunk
    5-stuck up or very slow power windows sa likod.
    1. only common sa model 95 pababa. 96 pataas napaka bihira.
    2. depende siguro sa kalsada na palagi mo tinatakbuhan.
    3. wala pa naman ako naranasan. baka depende sa shop na naglilinis.
    4. dahil yung labi na kinakapitan ng goma is malambot. pwede i DIY. pukpukin mo lang uli para umangat. matagal uli yan bago bumaba.
    5. wd40 lang katapat nyan sir. minsan kasi pag bihira mabuksan bintana natin sa likod e talagang nadudumihan kaya hirap. spray mo sa chanel mismo.
    Quote Originally Posted by LexTer View Post
    sir lexter, tama po, yung sakin, wd 40 lang ok na ulit power windows ko.
    yung sa aircon naman, sooner or later lalabas po yan, yan po yung tumitigas na foam under the dash board. hirap patangal kaya hintay na lang a ko lumabas sa aircon.
    sa stab link and trailing arm bushing naman, hmm.. baka nga the rough roads sa may lugar namin kaya ganon pero same din sa ibang ek owners na kilala ko.
    I think of all the engines I have seen Honda has a higher survival rates of overheating
    Jul 2006
    ano daw ang dahilan?
    sir lex, meron daw sa ilalim ng dash board na foam and kung tumitigas, sa vent na ang tuloy. pero mauubos naman.. wag lang tutok aircon sa mata kasi nakakapuwing. hehehe :bwahaha:
    May 2007
    Quote Originally Posted by ej_saiyajin4 View Post
    Pros & Cons.....NONE! I assume that you're really like that honda. If you maintain that car properly it will serve you faithfully. If you neglected on it that's the CONS.
    Jul 2006
    overheating?
    usually it is just caused by a stuck/non-functioning thermostat.
