Results 11 to 17 of 17
- Jul 2009
- 2,618
May 15th, 2020 12:01 PM #11not that the 1.3 is a bad car pero for your purposes practically wala atang advantage ang 1.3 vios over the 1.5.
buying second hand price difference will probably be miniscule year for year. ang nakikita ko lang baka mas marami kang pag pipilian na 1.3 models over the 1.5 which is still not a bad thing
- Apr 2008
- 6,235
May 15th, 2020 12:30 PM #12Pansin ko lang po, price is about the same for 2015 1.5 (old engine + 4AT) and 2018 1.3 (new engine + CVT). Kung city driving lang madalas, siguro halos hindi mahalata ang power difference pero maappreciate ang fuel savings in the long run.
Sent from my SM-G965N using Tapatalk
- May 2014
- 1,319
May 15th, 2020 12:31 PM #13Yun actually di ko magets sa Vios gen na yan.
Kung 50kgs heavier lang yung gross vehicle weight compared to before, parang isang small build adult lang yun e. Hindi dapat ganun kalaki naging effect sa performance/fc kung yun lang nagbago.
Hindi pwedeng sabihin na sa weight lang yung reason ng penalty kung 50kgs difference. Malabo din dahil sa air resistance kasi below 60kph naman city driving.
Mechanical tuning siguru nung sinalpak nila sa 3rd gen body or may losses dahil humaba siya ng kaunti?
Parang anlabo talaga nung nangyari in that gen. Same sa 2008/2009 atlis na single vvti. Tumakaw din from first gen altis compared nung year 2001. Lumaki din body nung altis nun compared to previous gen, pero iba talaga tuning nila dahil yung response ng makina to throttle inputs parang humina tlga. Maybe due to emission standards na humigpit. Sinakal nila yung makina.
- Apr 2008
- 6,235
May 15th, 2020 01:07 PM #14
May 15th, 2020 06:50 PM #15
1.3 manual dual vvt-i ang gamit ko consisted naman siya sa 9km/L Mix driving, Ewan ko lang mas matipid daw ang single vvti pero go for 1.5 minsan kase mas matipid ang malaki engine displacement kase di hirap ang hatak especially pag punuan palagi
Sent from my SM-G965U using Tsikot Forums mobile app
- Aug 2020
- 35
August 12th, 2020 07:13 AM #16vios 2011 1.5g at gamit ko. okay na okay tlga
fuel consumption: 10-12 mixed, express 16km/L
walang k problema sa batak,
wala pang palya, low maintenance.
August 12th, 2020 09:27 AM #17
A/T for city driving convenience.
Vios 1.3 weighs the same as a vios 1.5. So the 1.3 engine will be more stressed compared to the 1.5, needs to rev up more than the 1.5 pulling the same weight. 1.5 will have less wear on the engine. 1.5 will also have better fuel economy that 1.3. This last may seem hard to believe but it is a proven fact already the bigger engine is more efficient pulling the same weight.
That makes sense. Higher elevation has lower atmospheric pressure and even if the cooling system is...
