Results 1 to 10 of 23
April 9th, 2014 09:39 PM #1
Not sure if may thread na ganito pero ano mas prefer nyo mga sir? sabi nga sa kasabihan no replacement for displacement totoo ba?
April 9th, 2014 10:31 PM #2
Depends on the engine type, purpose and implementation.
And there are three solutions:
High displacement
High boost
High revs
Both turbocharging and high-revving are valid replacements for displacement. Of course, the best motors have lots of everything...
Certified MB Addict
- Apr 2007
- 2,284
April 9th, 2014 11:50 PM #3I'd prefer a naturally aspirated bigger displacement engine any day to a small turbocharged engine.
- Jun 2008
- 1,741
April 10th, 2014 09:24 AM #4Power to weight ratio i go for turbo charge engine.. easy maintenance i go the other way especially if the vehicle is to be use in remote areas away from spare parts availabilty.
April 10th, 2014 10:40 AM #5
In far-out places, a bigger, lower-revving naturally aspirateed motor will require less maintenance due to the low stress of running. Typically.
But with electronic control and more precise fueling and machining now pushing even turbocharged motors to the 200-300,000 kilometer marks, the fuel savings from downsizing makes sense if you drive in places where you won't be in danger of missing your 5,000 - 10,000 kilometer service intervals.
- Mar 2003
- 255
April 11th, 2014 05:06 PM #6additional question... which will consume more fuel if created equal... and same driving conditions... all Automatic... real world condition, no race track
Always wondered like between a V6 camry/accord VS legacy/forester/wrx (non-sti)
April 11th, 2014 11:12 PM #8
It depends. Technically, a smaller, boosted or high-rpm motor should consume less gas at idle if they're designed right, but constraints in terms of engine durability, engine bay heat issues, accessories and etcetera can change things.
A big engine with cylinder deactivation can use almost as little gas as a smaller engine at idle (for example, the Camry V6), but there is still the extra rotating mass of the "dead" cylinders that needs to be pushed around even when they're turned off.
And while a downsized turbo engine should technically use as little gas at idle as a non-turbo engine of the same size, the extra heat generated by the turbo usually makes it more thirsty.
"It's depends."
Truthfully, it depends. And most of it is down to the transmission/drivetrain (Subaru AWD has a lot of drag. CVT makes up for it, but not completely... Accord 6AT is fantastic and has low internal friction) and the specific engines.
Turbocharged engines will typically use as much gas as similarly powered naturally aspirated engines, but will produce more useful torque over a wider range of engine speeds... which means that they can be more flexible... that flexibility should result in better economy, but in the real world, results are mixed.
- Mar 2003
- 255
April 14th, 2014 10:10 AM #9Thanks... I guess street cred and bragging rights will be the other deciding factors :-)... gasoline consumption is too trivial for these kind of cars...
Subaru FXT are tempting in the 2nd hand market... but the v6 camrys and accord in the 2nd hand are also tempting!... just my thoughts :-)
April 14th, 2014 11:00 AM #10
very useful idea either of the two are good..kung pang karera siguro pwede de turbo kung everyday necessity syempre non-turbo. dun tayo sa mas efficient at makaka tipid.
