Results 1 to 10 of 50
February 10th, 2007 12:16 PM #1
Which do your prefer best? Toyota Yaris or Honda Jazz?
- For my side i highly prefer the yaris.
February 10th, 2007 12:28 PM #2
- I think March 2007 is the release date
here are the actual specs
Engine: 1.5-liter DOHC 16-valve VVT-i 4-cylinder
106 hp * 6000 rpm; 103 lb.-ft. * 4200 rpm
Ignition: Electronic, with Toyota Direct Ignition (TDI)
Transmission: 5 speed Manual
4-speed electronically controlled automatic overdrive (ECT)
Body Construction: Unitized body
Drivetrain: Front Engine; Front Wheel Drive
Suspension: Independent MacPherson strut front, torsion beam rear suspension with front stabilizer bar
Steering: Electric power steering (EPS): power-assisted rack-and-pinion with electronic power-assist
Brakes: Power-assisted front ventilated disc/rear drum
Imagine that may mc pherson struts ka na!.. hehe
Can't wait to see jazz vti smoked out with yaris.
"YARI KA SA YARIS!"
February 10th, 2007 12:34 PM #3
I've seen some Yaris in the US a few months ago, and I should admit that they do not excite me....
Opppssss, the ones there are sedans not hatchbacks....
1801:fuzzy:Last edited by CVT; February 10th, 2007 at 12:39 PM.
February 10th, 2007 01:18 PM #4
yes. thats the us version. toyota said that they will be releasing soon the hatch 4 door version there's also a two door version but i don't have any idea if it will be also avail.
February 10th, 2007 02:41 PM #7
Well the Jazz/Fit has 109hp and 105 lb-ft , 5 speed manual and 5 speed auto w/ paddle shifters. MacPherson struts up front and torsion beam suspension in the rear also.
FYI most cars have MacPherson struts suspension for the front so that's nothing special. As a matter of fact my 1998 Lancer uses it and so did my 1988 BMW. Now if you had said it had double wishbone then it would be different from anything in it's market.
