View Poll Results: VIOS vs CITY
Voters
497. You may not vote on this poll
  • VIOS
    242 48.69%
  • CITY
    223 44.87%
  • Others (Matrix, Lynx, Aveo)
    32 6.44%
Page 13 of 30 FirstFirst ... 39101112131415161723 ... LastLast
Results 241 to 260 of 853
    jovanne,
    The CVT has been around with Honda for the City and Jazz since 2001. Medyo tried and tested na ito. So far, it works like a charm. You feel the gradual acceleration just like an airplane. Plus, if your in a playful mode, it has the 7-speed mode wherein you could shift it manually, just like a video game.
    Oct 2003
    for the one week my bro had his new city, no problems whatsoever.
    jovanne, go and invest sa honda city. i dont think you will regret it, i know we didn't.
    Mar 2005
    We are also probably going to make the choice between Vios 1.3E MT and City 1.3S MT very soon...
    I'm leaning towards the City because:
    1) More space. The trunk is just huge, and can be extended with the ULT seats.
    2) 10K PMS interval.
    3) There's no Toyota dealership in my province.
    4) The gauges are where they should be, not center-mounted like on the Vios.
    5) The 1.3 i-dsi engine is probably more reliable since it's quite low-tech: SOHC with only 8 valves, and no variable valve timing mechanism.
    6) The EPS electric power steering is probably more reliable since there's nothing to leak, etc.
    Are those points valid? Or am I mistaken?
    Quote Originally Posted by Psylocke
    what do you mean low-tech?..
    yes it has 8valves but every piston has 2 sparkplugs...a total of 8 sparks
    imagine how fuel efficient this engine can be..
    it has variable timing, but not on the valve....sa sparkplug naman..
    Jun 2005
    In all fairness to Toyota, we got our test drive. Finally today.
    Final verdict ---
    the issues I mentioned above are:
    1) excusable in the case of the gearshift. Clutch is ok. Gearshift is a little tight
    (ramdam mo yong sabit lalo na sa reverse) but pwede na.
    2) the "kabig" is not noticeable...maybe I didn't get to drive it fast enough. Hanggang
    3rd lang kase nasa parking lot lang kame ng marquinton.
    Over-all feel is comfortable too. Middle console is kinda "nakakapanibago" pero it takes
    getting used to. Steering is okay. Handling and ride as well. Medyo makitid din ang shoulder
    clearance between the two front seats pero okay lang...kame lang naman ni misis most of the time
    (tsansing pa Feel ko pa parang gusto pa bumirit ng makina ng Vios. Malakas at mabilis talaga.
    Yong city umabot ako sa 4th sa Loyola, feel ko di siya aabot nang kasing bilis ng vios. Pero oks
    lang din kase di naman ako mahilig sa speed (sa traffic pa dito).
    I'm giving the Toy SA till 30th of this month to hack out a unit. Then it's go for vios
    (considering the difference in the prices between the two). But if by then, there's still no unit
    available, then the price increase of Toyota and the promo of the Honda will make them on even grounds;
    it'll be well worth going with the city. I also stand to lose the promo of the city by month's end.
    Sayang yon. So there.
    Thanks to all for the helpful info.
    Mar 2005
    Quote Originally Posted by ozcity
    No it's not low-tech per se, it just doesn't have those vvti or vtec things that add complexity (and performance) to an engine.
    With those 8 spark plugs is it safe to say that the City is more fuel-efficient than the Vios? By how much?
    Oct 2003
    nice choice monmag! hehe we're thinking of getting another one, kung mabenta yung mga other cars dito sa bahay..hahaha :D check your PM
    Sep 2005
    Tanong lang po, ang toyota vios ba naka-timing chain ?
    Oct 2004
    Quote Originally Posted by jaivin100
    yes, toyota vios uses timing chain and not timing belt.
    Sep 2005
    Quote Originally Posted by rayana
    thanks rayana, kasi wala akong makitang maintenance regarding sa timing belt 4 vios. Kumuha nako ng vios talagang matulin ang vvti kahit 1.3 lang. Saka talagang maingay........yung sounds dahil 4 speakers sya.he he
    quality = City..
    Jul 2004
    question lang po... malaki po ba ang difference ng 1.3 i-DSI sa 1.5 VTEC ng city?
    May 2005
    Quote Originally Posted by knicks1204
    Engine-wise
    1.5VTEC
    VTEC 16 Valve
    1496CC
    Maximum power - 110PS / 5800 RPM
    Maximum torque - 14.5KGM / 4800RPM
    1.3 i-DSI
    4 cylinder SOHC chain drive 1.3L i-DSI
    1339CC
    Maximum power - 82PS / 5700 RPM
    Maximum torque - 11.8KGM / 2800RPM
    Feature-wise
    1.5 VTEC - bigger alloy 14" wheels
    1.3 i-DSI - "A" - 13" steel rims
    "S" - 13" alloy
    Quote Originally Posted by number001
    Feature-wise
    "S" - 13" alloy
    afaik the 1.5vtec has 15" rims..
    Jun 2005
    Oz's right 1.5 vtec has 15"
    Number, the 1.3 "A" has 13" steel (correct) pero 1.3 "S" already has 14" (alloy tama) and not 13".
    Other little things --- third brake light, side moldings/protectors, fog lamps...wala lahat yon sa 1.3 na tingin ko meron sa 1.5
    Pero siguro ang tanong ni knicks e more on the engine...tama yong specs ni number. Laki difference. Kaya laki din diff sa presyo
    jaivin, afaik vios vvti has timing belt (anyone correct me kung mali).
    Jun 2005
    add ko pa (sorry hinanap ko pa url kaya nag double post pa ko)...
    http://asia.vtec.net/Series/FitJazz/lseries/index.html
    sabe ng iba parang backward yong features ng i-DSI (with its SOHC, 8-valve, chain). I also thought so. Pero to learn the minds behind the design, check the addy above. Pati vtec, may discussion don.
    Aug 2003
    ok yung torque curve nung 1.3 ah... parang diesel. peak torque at only 2800rpm!
    i think that would help the drivability a lot kahit mas mababa yung hp.
    sabi ng nanay ko kagabi
    ..maingay yung VIOS mas gusto ko yung City tamihik
    hehehe diko alam kung ano ibig nya sabihin sa "maingay"
    Jun 2005
    Baka kase 4 speakers ng vios? hehe...
    Pero share ko lang true (almost katangahan) experience ko:
    so park ako, off radio at a/c. hintay sa misis.
    Maya maya, paalis na kame. Muntik ko uli ma crank engine ko (buti na lang hindi). kung saka sakali, ang sakit nong grinding sound it would have created.
    nawala sa isip (buti naalala) ko na naka idle pa pala ako!
    Pero talagang tahimik at alang vibration pag idling.
    So ingat lang sa city driver (na medyo makakalimutin) kase baka masira starter n'yo.
    Aug 2005
    medyo ot po: ako po it's either vios, jazz or altis j! planning to buy din e!
    ngayon po wala na sa options yung jazz, it's either we go for vios, new city or altis j.
Toyota Vios vs. Honda City [Merged]
