Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Jan 2003
    guys please help. i need an enlightenment. i need to know some comparisons between pajero jr and suzuki jimny. I want to know your verdict as well.Thanks in advance.
    for me. a pajero is still a pajero. maski pa second hand yan, o surplus.
    but of course, it will all depend on the condition of the unit.
    for the jimny, although its a great compact offroader, limited yung engine power nya. hanggang dun ka na lang. mataas pa center of gravity.
    but then again, its just me.
    Oct 2005
    wala ako alam sa mga maliliit na 4wd pero para sa akin, mas maporma ang paj. ang cute cute nun.
  4. #4
    remember they're both used..so take your time looking...
    pajero jr: 94-96..some are 98+ jdm model year (check mo seatbelts) 660 turbo..common ang 3-speed a/t, mayroon ding 4-or 5-speed manual, conventional 4wd(2h-4h-4l)..compact and mas makakapalingon kaysa sa jimney..kasi bibihira ang looks.
    downside:being imported and di relased locally, finding replacement parts is a challenge. pero iba ang class-a japanese used car compared sa class-a local natin..
    jimny:1300 cc, 2000+ model (local) 1990++, 660cc turbo (imported, particularly JDM) a/t or m/t. masmadali parts nito, kasi kahit imported, madaming enthusiast nito dito compared sa pajero jr., but kung ung 1300cc, masmatipid parin ung 660cc...
    bottomline, hanap ka ng maganda-ganda unit na gusto mo..i advice manual on secondhand..you'll never know kung sira ang a/t hanggat di na tumakbo yan...ok naman a/t, basta be sure to check that the oil is red-pink in color and smells sweet...otherwise, iwan mo yan, no mater what it look like.
    vitara 2-door?o gusto mo talaga mini SUV...
    Jan 2003
    Quote Originally Posted by alwayz_yummy
    Thanks sir yummy. Your post is very informative, although, because of the the contradicting posts here, im a bit confused now as regards the mini and the jr........You mentioned "660 turbo," for the paj jr., does this mean 660 cc displacement? But, some specs say "1100 cc a/t" for instance.Is this a different variant?
    I also considered the vitara but, accordingly, it is a gas guzzler, especially the a/t model, isnt it?
    Quote Originally Posted by conzky
    I have a couple of officemates both using 02 1.6l Vitara Matics. Accdg to them, they just get 5.5-6.5km/li on city driving.
    Oct 2005
    btw, whats the difference between the Pajero Jr and Pajero Mini...
    im confused.... isnt it that the Pajero Jr is the 3door Pajero and the Pajero Mini is the scale down 3 or 5door Pajero (the one that looks like a Jimny)
    Oct 2005
    im confused.... isnt it that the Pajero Jr is the 3door Pajero and the Pajero Mini is the scale down 3 or 5door Pajero ?(the one that looks like a Jimny)
  9. #9
    pajero jr and min i think are the one and the same....
    minsan nakita ko kasi sa 4x4mag ko, pajero mini siya, pero ung mga dumadating JDM dito, ang badge nila ay pajero jr...
    iba ang pajero IO...ung mid-range nila pantapat sa cr-v, rav-4,vitara...1.8 GDI,GDI-turbo 2.0GDI(ata) meron nito..
    me i like a 3-door pajero IO na lagi ko nakikita malapit dito sa amin..and chicks pa ang nag-ddrive! (minsan gusto parahin para makilalako ung magandang..........
    chick...este IO pala
    Magkaiba ang Pajero Jr. and Pajero Mini. They belong to different classes in Japan.
    The Jr. is bigger than the mini. The Io is bigger than both. Then comes the Pajero Sport and finally the full-size Pajero.
    Jun 2005
    try mo feroza
    Quote Originally Posted by pitbullz
    try mo feroza
    hmmm.lam ko bro di masyadong maganda performance neto eh.
    why not an old model (circa 96-97) vitara instead?
    Jun 2005
    look under the hood and also check the under chassis you will know the difference between the vitara and the feroza problem is wala na daihatsu dito sa atin an bad trip sa columbian... napalitan na siya ng ROCKY ngayon, but 4x4 people across the world specially in australia and malaysia still prefer the older feroza kesa dun sa bagong rocky. from the words of cruven owner claro- this truck was built for punishment
  14. #14
    1.6L dohc ang vitara, 2-door version, manual may be mas matipid, less weight,maybe..
    baka nga iba ung 1.1L, pero most nakita ko noong nag-iikot ako for JDMs, are 660cc gasoline turbo with mostly A/T..pop the hood, pag may intercooler and turbo, at check mo ung VIN plate, nandun lahat un...
    Aug 2005
    2 door paj japorms. vita 16 valve lng
    Jan 2003
    Thanks for all the inputs. i appreciate it very much.
    First generation Vitaras ('95 up) can do 7-9km/L on a light foot and stock tires.
  18. #18
    parang 2.0L! di nalalayo ata sa crv and rav4
    Yup. Because its built like a truck [heavy] and medyo old school so not as efficient.
    i'll take the jimny
pajero jr (japan surplus) or 2nd hand suzuki jimney
