Originally Posted by
niky
You can't expect a 1:1 correlation between a video game and real life. Factors such as air pressure, wind speed and direction, ambient temperature, coefficient of friction of the track, track temperature, tire pressure, coolant temperature, fuel level, driver weight, etcetera... make most 0-100 km/h times suggestive rather than definitive. I can get a 0-100 km/h time that's 3/10ths faster simply by finding a road that's slightly downhill.... or by driving on an empty tank... or by finding a launch pad with better grip.
Depends on the power of the car. A naturally aspirated 2 liter car with a crappy four-speed automatic is severely handicapped when it comes to the "launch". The only way you can get to 100 km/h in 8.5 seconds with, say, a Honda Civic, is to rev the car out to 5000 rpm and dump the clutch. Can't do that in a 'matic. And most ATs have longer gear ratios than their MT counterparts.
If the car has enough torque to break traction, the AT will only be slightly slower than the MT. The Focus TDCi numbers? 8.6 seconds for the 6MT, around 9.2 seconds for the 6DCT Powershift. Both six speeds. So, despite being around 50-60 kg heavier, the Powershift is only 0.6 seconds slower.
Maybe you're talking about American times? Because a 0-60 mph time is actually 0-96 km/h. And that's a lot shorter than a 0-100 km/h time. For a car with that little power, the difference will be around 1 - 1.5 seconds (depending on where the shift from 2nd-3rd lies... usually you have to shift into 3rd before 100 km/h).
Most 0-100 km/h numbers I've seen for the First generation Jazz (which is faster) hover in the 10+ second range. In my testing, the AT Jazz is around 11.5 seconds.
The 2010 Jazz does 0-100 km/h in about 11.2 seconds with the 5AT. US sites post a 0-60 mph time of around 8.5 with the 5MT... that would be about 10 seconds, likely, when converted to 0-100 km/h. That's a mere difference of around 1.5 seconds, just about right.
