Results 1 to 13 of 13
    Feb 2011
    hello po!! newbie lng, pro matagal na po ko ngbabasa ng mga threads dito, finally time ko na rin magtanong.. hehe.. balak ko po kc bumili ng oto, kaso 130k lang po budget ko pati pampaayos na kung sakali.. wise po ba kung ibibili ko un ng sentra series 3 1.6 efi? o sentra lec 1.3l carb na lang? kasi pg series 3 konti nalang sukli ko baka nga wala pa.. pero kung mas matipid naman yon ng malayo sa lec cguro mas ok nmn in the long run.. pls help po... thanks!
    ps:
    pa suggest narin po ng ibang options fc lng nmn po at power steering ang concern ko.. hehe
    [SIZE="4"]REMINDER: do not post messages in SMS/TXT shortcut format & grammar. Use proper sentenses and paragraph construction. If your posted message is hard to read, less people will read it & respond.
    Read the RULES.
    Ignorance is NOT an excuse.
    Repeated offenses will lead to banning.
    [/SIZE]
    Apr 2008
    Quote Originally Posted by nelren_24 View Post
    ps:
    Stay away from the LEC. I have a relative who owns a Sentra LEC-PS. As with a Nissan, the aircon is very cold, so cold that our Trooper cannot compare. But the engine is weak and thirsty. And being a carbureted engine, there are the usual problems like having to calibrate it every so often... If you're gonna buy, always look for EFI engined cars. Get the Series 3 for a better looking, more powerful, and more spacious car.
    Feb 2011
    sir gti! salamat po ng marami! isa pa po tanong, pano po ba malalaman kung nalubog na sa baha ang car? malalaman po ba yun ng mekaniko agad sa meet up? tsaka ano po ba ang dapat kong asahan na masisira agad kapag bibili ng 2nd hand cars? para mapaghandaan narin po.. hehe
    Apr 2008
    Kung magaling yung mekaniko kumalikot, siguro. Although there may be cases na talagang immaculately restored siya after being flooded to the point na walang trace na nabaha siya (which is the case of the Mazda 6 ng anak ng isang ninong ko, which spent almost a year in the casa... ). With the sloppily remedied units, usually medyo mabaho ang loob, yung tipong damp smell. And then you might be seeing rust here and there, try peeking on the metal parts inside the car and under the carpet, beneath the car and in the engine bay. And if you notice that the exhaust pipe isn't in good condition (yung parang maitim na, puro kalawang, at parang uling nalang ang natira), avoid at all costs kahit maganda pa ang body niya along with a shiny paint job, this usually hints at an engine that is in bad condition. Test drive the vehicle in different kinds of driving environments. Listen for any sort of kalampag from the engine and the suspension. Maraming ways kung paano makahuli ng mga ganon, hindi ko maiisip lahat kaagad, though there is a thread here that discusses about how to find out if a car was flooded, search mo nalang iyon.
    Apr 2004
    tignan mo na lang yung bolts that hold the seats to the floor. pag may kalawang ibig sabihin nababad. wala naman dahilan para kalawangin yun unless tinaggal yung bolts isa isa tas binabad sa tubig tas binalik (what kind of idiot would do that naman?).
    tapos run your finger sa ilalim ng hinges ng mga pinto. turo sakin ito ng buy and sell na pinsan ko... and amazingly enough, after more than 1 year na nangyari yung ondoy, andami pa din putik sa lugar na yun pag tumitingin ang pamilya namin ng 2nd hand (tas sabi ng seller flood free... utut mo brown yung putik/alikabok eh! hehehe).
    Instead of a LEC, you can go for a 92 Sentra Super Saloon with ECCS. It's not carbureted.
    But a 3 series would be a good way to go. Go for the 1.6GE ECCS engine. same engine as the 2nd series SS Sentra. There's some nice ones out there in the market.
    Open up the engine bay, check the corners of the engine bay..the frame. make sure you see no welding. it should be smooth. all doors must close and shut properly. Stay away from lowered cars...it means that the owner did a lot of modifications to it. stay with stock cars.
    There's some nice ones out there..be patient and don't rush.
    Goodluck
sentra series3 or lec for tight budget
