Results 1 to 10 of 17
- Dec 2007
- 12
September 6th, 2009 10:15 PM #1Hi tsikoteers. Mars here. I'm planning to buy a 2nd hand AUV and it's a toss-up between a Revo (GLX or SR) and a Crosswind (either XTRM or XUV). What is the smarter choice in terms of performance, ground clearance, maintenance cost i.e change oil, fuel consumption, etc. ?
I prefer an automatic transmission. Thanks in advance.
- May 2009
- 406
September 6th, 2009 10:39 PM #2In terms of performance, the Revo 1.8 is faster than the crosswind hands down. Now if you put an automatic transmission on the crosswind, it gets worse. The Revo gets this one.
Ground clearance, they're both pretty much comparable. Last time I checked, minimum ground clearance for the XUV crosswind is around 185mm. Not sure with the Revo but they won't differ greatly.
Maintenance cost, the crosswind is just drive and go as long as you religiously change your oil. The Revo engine I'm guessing is also quite bulletproof.
In terms of fuel consumption, the Revo 1.8 A/T is similar to a Ford expedition, expect around 5-6 km/l only. The Crosswind on the other hand is the exact opposite, maybe around 10-11km/l on the automatic, the M/T gets more.
Maybe there are other options you can also look at within your budget. But between these two, I'd get a crosswind but a manual at that, the automatic is just too slooooooooow. Goodluck overtaking tricycles inside subdivisions.
- Dec 2007
- 12
September 6th, 2009 11:25 PM #3Thanks for replying. It was very informative and helpful. But since I currently drive a manual car and experience heavy traffic (slex/skyway 2nd phase), it has been really tiresome. I've heard from others that Revo is a gas guzzler. With high price of fuel, I think I would go for the Crosswind diesel. I wouldn't mind the slow acceleration
- May 2009
- 406
September 6th, 2009 11:31 PM #4Are there any other cars that might fit in your price range considering the crosswind XUV A/T is still priced quite high? Maybe there are better options you can consider, if not the crosswind is a solid vehicle that won't give you headaches.
September 6th, 2009 11:40 PM #5Goodluck overtaking tricycles inside subdivisions.
I will choose the AT Crosswind if you value fuel economy.
September 7th, 2009 12:40 AM #6
- Dec 2007
- 12
September 7th, 2009 12:46 AM #7No other vehicles on my list. However, I did consider a used Innova but its ground clearance is too low for me..(for floods and easier ingress/engress). A 2004 Crosswind XTRM would set me back over half-a-million, it's quite steep- for me atleast since I'm not well-off. As for a Revo 2003-04 it ranges from 400k-480k. There's a significant price difference between the two, provided I can still haggle, but I'm leaning more on which can give better mileage and less trip to the pump station.
- Dec 2007
- 12
September 7th, 2009 12:53 AM #8
- Dec 2007
- 12
- Dec 2007
- 12
September 7th, 2009 01:01 AM #10Oh yeah I did consider the Suzuki APV. I liked its width and g.clearance but I've read in the threads that it has poor FC. So it's out of the question.
Production of the next gen Kicks confirmed .......
2025 Nissan Kicks
