Results 1 to 15 of 15
    Apr 2006
    I'm about to buy a second hand van for my family. My Toyota Liteace 92 is ageing and Gasoline prices is really uncontrollable.
    I'm now zeroing my site at these 2 van ... Spacegear GLX 4WD vs Starex 99~2000 diesel . My maximum budget is 320k only.
    Now my concern is during flood and some points that I will mention. Lets face it Ondoy will happen again and some how we will be affected and in some cases we cannot turn back with it.
    Lets pressumed both van is in very good condition and very good conversion.
    Here are my questions
    1. Which of the 2 van will survive in a 2ft flood? 3ft flood?
    2. Starex - I haven't seen a lifted Starex well at least 2 to 3 inches, is there any major risk or any drawbacks? If there is any saan shops pwede magpalift? how much?
    3. Spacegear - nadadaya ba ako ng mata ko bakit parang mas malapad yung tingin ko sa local na GLX kaysa dun sa Japan na GLX 4WD?
    4. Sa mga pang-ilalim alin ang mas matibay yung sa SPACEGEAR GLX 4wd or yung sa Starex 99~2000. Pag nagbabasa ako sa mga topics dito sa tsikot parang naamoy mas madaling masira yung pangilalim ng starex kaysa sa spacegear or dahil 4wd si Spacegear?
    5. Anong ideal na makina ipalit sa STAREX 99~2000 in 50k budget, ayoko CRDI dahil mahal. Yung makina na para lumakas lang ng kaunti ... like 2.6 to 2.8cc diesel.
    6. Diesel consumption, which of the two ang mas matipid for daily use? and trip to Baguio?
    Hope you can help me ... in 3 months time I'll be buying a van in replacement of my old Liteace.
    Apr 2008
    The Starex is basically just a rebadged, reskinned and more refined Space Gear. In terms of flood wading capabilities, the Space Gear should have the upper hand due to the taller ground clearance and even more so if you have a snorkel installed. The fuel mileage of both are rather dismal AFAIK, especially in matic form. One may be better than the other depending on load conditions and road terrain. You may also be interested in getting a 4x4 Starex, there are some of them in the market and it relieves you of conversion problems. Engine transplant for the Starex? I'm not sure if that will be a good thing to do but finding a 4M40 used in the Space Gear should do the trick with no or minimal modification.
    1. Surviving depends on your definition of surviving. Is it making it across without any damage or consequences or just plain surviving?
    Anything below the door sill is easy enough for both of these vans. Just change the differential and transmission fluids regularly along with some bearing grease and brake cleaning. The converted unit might have more holes on its firewall due to the conversion process which may allow water to enter the cabin should you decide to ford deep water.
    2. Just get a 4x4 Starex. As said, the Starex is a licensed and refined version of the Space Gear. There are some units on the market. Some in the top of the line 'CLUB' version. Regular vanilla joe 'SVX' versions are also available.
    3. Yep nadaya ka. They are the same width door skin to door skin. Some Japanese models are wider still owing to their fender flares.
    4. Pretty much the same in the durability area considering both use the same brand of replacement parts for the underchassis.
    5. A Starex Turbo Intercooler 4x4 model already makes 100horsepower (same as a 2000 model 'millenium' look Starex). Same as a Spacegear with a similar engine (local Spacegear diesels with no intercooler makes less power). How much power do you need or want?
    6. Again they are the same car basically. So don't expect a big difference in consumption when equipped with similar engines and transmissions. The 2wd Starex might get better mileage due to better aerodynamics and lighter weight but not by much. The 4x4 Starex will get the same mileage as the Spacegear.
    if i don't need the space and the seats, i'd get a diesel revo, adventure or hilander. easier to drive na, cheaper on the fuel pa.
    and engine-under-driver configurations don't ford floods too well.
    and i would forget planning my car purchase for ondoy. that was a fluke. think daily use.. otherwise, you'll never be happy with anything short of a hull with wheels..
    The Starex/SpaceGear are both full front engined vehicles na po. Delica Star Wagon yung nasa ilalim ng seats ang engine.
    Personally, the Starex turbo intercooler with a/t is way better to drive than a Revo or Crosswind (both a/t's also). Mas malakas lang ng konti sa fuel. But it is a full 9 passenger wagon with room to spare for luggage. It's just like driving a GEN II Pajero. The Crosswind feels anemic and the Revo feels very stiff compared to the Starex.
    Apr 2006
    Sorry sir taga-Pasig ako. I need to think about Ondoy also or any flood. 3 weeks ang baha sa amin. At kadalasan pag umulan ng malakas talaga karamihan baha na sa mga dadaanan ko pauwi. At kadalasan umuuwi din kami ng Asingan, Pangasinan kung magpakawala na naman yung San Roque Dam? Tsaka we always go to Agno river which is a quarry site so rough road and hope to do some river crossing probably 1 and half deep water.
    Minsan kasi nakita ko lumusong yung Delica na 4wd yung before Spacegear ang itsura ... lusot. Yung Spacegear na 4wd na converted or Starex 1999~2000 lulusot kaya?
    Apr 2006
    Sir Otep,
    Thanks for the great info.
    1) I was refering Spacegear GLX 4wd (converted) comparing to Starex 1999~2000. You mean sir their engine are almost the same in power 2.8 vs 2.5?
    2) Power? just enough to make across from 2ft to 3ft water if possible without any damage or consequence and Probably flash floods.
    3) For Starex 4x4 aren't they are in the range of 400k plus. I think I mentioned my budget is 300k only.
    Hindi po ba generally mas matibay ang mga pangilalim ng 4wd kaysa 2wd? Especially in the case of Spacegear 4wd(converted) vs Starex 1999~2000?
    Pwede pa ba ilift or lakihan ang tire ng starex para tumaas ng konti habol ko sana kahit mga 2in lang. Any disadvantages or consequence?
    Quote Originally Posted by xsugo View Post
    Sir Otep,
    1. 2.8 makes 120 bhp, 2.5 makes 100bhp. For me its a non-issue. I've driven both engines in a Pajero and frankly, the extra 20bhp is appreciated if there but not entirely missed when its not. The Spacegear is also saddled with the extra weight of the 4x4 drivetrain (front axle and transfer case).
    2. Water fording is a skill and without proper training, even 'real' SUV's can get damaged. The Space Gear and Starex were not designed as boats. And as I said, anything below the lower edge of the door sill is easy. Anything above the midpoint of the tire is pushing it already. I drive in water with a bow wave up the top edge of the front bumper or the headlamps and I've done this on a variety of vehicles. From a Suzuki Jimny to a '96 Pajero. I can't guarantee any results should you try to do this on your own vehicle. Heck, I can't even people to NOT step on the clutch while fording water and instead they employ the jeepney driver method of revving the engine like sh*t while in the water. Which isn't really what you're supposed to be doing midstream.
    3. Ok, didn't know what the going rate was for ex-Korean Starex vans. They're cheaper than local ones.
    4x4 vs 4x2 on these vans isn't really rocket science. The vans are bascially 4x2 pick ups underneath so they are pretty strong. They are not traditional road going minivans like, say a Kia Carnival or Chrysler Town and Country. So the addition of a front drive system really didn't entail much reinforcement or modifications. The parts that usually fail like ball joints and tie rods are easily replaceable.
    Getting a 2" lift on a Mitsubishi Pajero is already very difficult. It's the same case with the Starex which uses the same suspension design. And it can get expensive. So might as well save up and go for a 4x4 Starex if you really need the height. Even a Korean surplus (with the B plates). At least you won't have modification or conversion issues.
    Apr 2006
    Again lots and lots of thanks sir Otep.
    Palagay ko Starex 4x4 talaga yung bagay sa akin ... Reading from the threads which is kokonti lang talaga ang bumabangit sa mga 4wd or 4x4 na Starex dito sa tsikot. Wala pa halos bumangit kung gaano kalakas ang consumption nito sa Diesel ... like going to baguio if 4x2 Starex mga 2500 pesos then 4x4 Starex will be something in 3000 pesos.
    Sa ibang website ang specs na nakita ko almost the same yung consumption like 8/100km yung 4x4 yung 4x2 parang nasa 9/100 basta halos isang puntos lang ang difference, kasi nga halos pareho 2.5cc yung engine but magkaiba lang sa hp. Pero syempre iba yung galing sa actual experience baka kasi yung specs na nabanggit ko sa itaas bagong-bago yon.
    Tapos yung ground clearance 9in sa 4x2 then sa 4x4 13in halos 4in difference ... which is OK na rin.
    Sir, bakit nga ba konti lang ang 4x4 na Starex especially yung model na 98 to 2000 (sorry yun lang kaya ng budget ko)? according sa mga threads dito parang may mahirap palitan na pyesa dun sa transmission pag nasira or talagang sirain yung transmission?
Flood Survivability: Spacegear GLX 4wd vs Starex 99
