Results 1 to 12 of 12
    Feb 2012
    Hi po sa lahat,
    Hingi po sana ako ng advice kung alin sa dalawa ang mas ok Lancer 1.6 gls or avanza 1.3E AT.
    Engine quality, security features, etc.
    Thank u
    Sep 2005
    dapat Avanza 1.5G A/T
    Feb 2012
    Budget issue
    Oct 2007
    they have different categories.... tell us more with your requirements and criteria like seating capacity so we can be able to put inputs
    Dec 2011
    Quote Originally Posted by Phedscom View Post
    Hi po sa lahat,
    Thank u
    1.6 is better than 1.3.
    Feb 2012
    Atleast for 5 persons.
    Habol ko ung mas ok na engine and security features.
    Thank u
    Sep 2005
    for 5 lang pala sir.. bakit avanza yung napili nyo i compare?? why not honda jazz? city kaya? or toyota vios?
    Mar 2004
    E, kung sinasabi ng TS na at least 5 person, pasok ang lancer 1.6 gls. E pag sumobra? Just bear in mind the term "at least". HIndi na pasok sa comparison ang lancer dahil 5 seater max lang sya?
    so, IMO, 5 pax seating - lancer, vios, city, sentra all sedans
    above 5 pax seating, avanza, adventure, crosswind.
    It would be disadvantageous to compare a sedan against UV, if the passenger requirement is only 5 person. Likewise, its a disadvantage to a sedan if the passenger requirement is above 5 persons.
    so my final answer? this is a mismatch
    Mar 2004
    Di ko ma edit.
    correction. It would be disadvantageous for an UV to compare it to a sedan if passenger requirement is only 5 passengers
    Jul 2003
    oo nga naman. magkaibang categories. sedan vs MPV.
    kung yan ang choices, mag desisyon ka depende sa pangangailangan mo.
    yung security features madaling i-compare kahit different type of vehicle.
    pero yung engine, 1.6 sedan vs 1.3 MPV. my logic says 1.6 sedan will have better economy.
    pero kung ikaw yung tipong mahilig magdala ng madami, mas merong space ang Avanza. the fuel economy may suffer pero it can satisfy your need for space.
    ako given the same price, Avanza pipiliin ko dahil mas kelangan ko space at yung ride height. the fuel economy maybe lower than a sedan pero accepted ko na iyon. dadaanin ko na lang sa tamang pag-drive e.g. no sudden acceleration and braking, on-time change oils, proper tire pressure, removal of unnecessary weight inside the car, etc.
    so ilista mo muna yung needs at priorities mo regarding sa gusto mong sasakyan.
    Feb 2012
    Sorry po sa maling comparison.
    Maraming salamat po sa lahat.
    i am assuming you have already done some homework and that these two are what you have narrowed down your choices to. therefore... hinde! hindi mali ang comparison mo. us users, we don't care if we compare horses with giraffes. we don't care if the comparison is fair or not. all we want is, which will fill our needs better for the money we are willing to pay.. my opinion is to get the avanza. its newer technology should serve you longer and more reliably. unless, of course, if you have special needs..
    my 90 centavos' worth..
