An
indirect injection diesel engine delivers fuel into a chamber off the combustion chamber, called a prechamber, where combustion begins and then spreads into the main combustion chamber. The prechamber is carefully designed to ensure adequate mixing of the atomized fuel with the compression-heated air. This has the effect of slowing the rate of combustion, which tends to reduce audible noise and softens the shock of combustion and produces lower stresses on the engine components. The addition of a prechamber, however, increases heat loss to the cooling system and thereby lowers engine efficiency and requiring glow plugs for starting. In an indirect injection system the fuel/air mixing occurs with the air moving fast. This simplifies injector design and allows the use of smaller engines and less tightly toleranced designs which are simpler to manufacture and more reliable.
Direct injection, by contrast, uses slow-moving air and fast-moving fuel; both the design and manufacture of the injectors is more difficult, the optimisation of the in-cylinder air flow is much more difficult than designing a prechamber, and there is much more integration between the design of the injector and that of the engine it is to be used in.[1] It is for this reason that car diesel engines were almost all indirect injection until the ready availability of powerful CFD simulation systems made the adoption of direct injection practical.
