Results 1 to 2 of 2
    Nov 2011
    Mga master pa help naman po mag decide between this two van?
    Gagamitin ko po kasi sa small biznes ko na Pisonet pang deliver po at pang gala na rin ng pamilya
    tanong ko lang po kung ano ang PROS and CONS ng dalawang van na ito
    give feedback na rin po about:
    1. Fuel Consumption (City drive/ Long Drive)
    2. Reliability (City drive/ Long Drive)
    3. Availability ng Pyesa pati narin sa PRICE
    4. Maintenance
    5. multi tasking job nito
    thanks po
    Sir andrei79,
    For business, I would say go for the Multivan since it consumes far less than the Liteace. Maintenance wise, I think parts are can easily be found on every auto supplies. I would only go for the Liteace if it will be used for Family purposes, though you might have second thoughts on its fuel consumption plus the overheating issues. You might want to also consider the Tamaraw FX diesel, here you get the fuel economy plus bigger space which can easily accommodate your family requirements. If you'll decide on buying the Multicab or multivan, better check it's conversion (if its imported from Japan) if its safely done, and used proper conversion kits.
Toyota liteace 5k engine o suzuki multivan  f6a engine
