Results 1 to 10 of 13
December 24th, 2009 02:53 AM #1
Patulong po mga bosing sa pagpili ng kotse: Toyota 98 XE or Honda 1996 LXI
My budget is 200k
Ang mga hanap ko po ay Manual
Cheaper parts accesories
Fuel Efficiency at tsaka po reliability
Thanks In Advance!
- Apr 2009
- 1,902
December 24th, 2009 06:54 AM #2Both cars are reliable and fuel efficient, but here are some differences you might want to consider:
CoRolla XE = 1.3 carburated engine (pls correct me if im wrong. not sure about the 98 model)
Civic LXI = 1.5 fuel-injected engine
The Civic should be more fuel-efficient in both highway/city drivings.
Certified MB Addict
- Apr 2007
- 2,284
December 25th, 2009 04:13 AM #5
December 25th, 2009 02:49 PM #6
civic lxi. safety lamang naman yung xe98 may 2 airbag na and alam ko all power na
December 26th, 2009 02:34 AM #7
Corolla XE hands down.
Low cost and availability of parts? check. Thanks to the buying power of thousands of taxis, you can get cheap parts almost anywhere.
Fuel Efficiency? check. A good spraydown of carb cleaner down the throat once in a while is all you need to do. If my mom can clean carbs, so can you.
Reliability? Look at those taxis... literally held together by wire and duct tape... driven almost a hundred thousand kilometers in a month... yet still running. I've yet to see that level of durability in a Honda, because they're so babied and pampered. And when they break due to some engine code thingamajig, you have to bring them to the CASA, where you are at the mercy of the snooty-toot Service Advisor. With a Corolla XE you simply call your corner mechanic and buy parts at the corner auto supply store. And with the simplicity of its 2E engine, reliability is never an issue.
Accessories? Pareho madami sa Banawe.
December 26th, 2009 04:23 AM #8
wow maraming salamat po, kaso yung bibilhan ko na 98XE nag backout kaya hanap po ako ulit ng ibang kotse. salamat po ulit!
December 26th, 2009 08:08 AM #9
you don't buy a bike kasi may extra savings ka from somewhere... just buy a bike. explain later...
All New Toyota Corolla Cross
