Results 21 to 40 of 49
    Apr 2005
    Quote Originally Posted by vedder
    budget ko kase is mga 250 to 300k.. seems cross out ko na sa options ko ung glxi.. if you were on my shoes.. which would you get? SAKIT pala sa ULO nito..
    Personal choice ko is CIVIC, with a 250-300k budget baka sakali pde '96 or '98 vti.
    Aug 2003
    i think meron namang mga later-model civic for 300k... check mo sa buyandselph.com...
    Feb 2007
    Hello there, I'm also faced with the same dilemna on which of the above cars to choose , mit glxi 99, civic vti and corolla gli 99. I'm more inclined to choose corolla but I'm still listening to your further views . Gli 99 would be perfect if not for the slightly tight interior space, Civic is really durable too. These cars score above average in terms of reliability according to Consumer's Reports here in North America.
    If I'll go home to the Philippines , I would consider buying any of these 2 cars, but I'd like to hear more of your expert opinions before finally deciding.
    May 2005
    sir roly, actually po lagi ako nagtsetsek sa buyandsellph, buyandsellplus, even here sa tsikot.
    just seeking advice lang po kung alin maganda bilhin
    May 2005
    actually medyo nafrustrate ako, kse type ko talga origanally is Lancer (pizza pie) for its external appearance kase mukhang masarap ayusan... kaya lang ang dami bad reviews (kalampagan, servo kit is plastic madali masunog) so i have to trim down my choices sa civic (which is medyo mataas and presyo baka mabitin budget) and corolla gli (sabi naman ng iba masyado common "taxi")
    Apr 2005
    CIVIC ka na heh he. Ingat lang kung masyado mababa than going rate, baka may problema yun.
    Jan 2003
    we've owned a lancer pizza since 1996. don't expect a car over 6 years of age would have a suspension perform like a brand new car. hindi sakit ng ulo ang Lancer.
    ipinagawa ko yung suspension ng lancer after 8 years of abuse. ngayon, syempre wala na syang kalampag. naiuwi ko na ito sa quezon province (sira pala ang kalsada dun) pero buo pa rin. ok naman ang performance, and parts are really plenty.
    yung ibang tao kasi dito ndi pa nakakahawak ng lancer eh kaya biased. mga balibalita lang. hehehe :D
    pero kung mag rerezing-rezing ka, civic. mahal ang pa-swap ng makina ng mitsu eh.
    May 2005
    1996? di ba 1997 oldest model nun
    Jan 2003
    bought in 96, pero 1997 model ok? first batch itong amin.
    try test driving one first before making any decision. parts of those cars are plenty.
    If you want a sportier drive, get the Civic, but if it's reliability you're after, the Corolla is for you. Whichever you choose, you can't put a foot wrong. ;)
    The Lancer is not a bad car. I've driven a GLXi, though it's the older egg type (94 model). It's worn out, yes, but also partly because of lack of proper maintenance. My own GLi also doesn't undergo regular check-ups since it has to be used almost everyday. Right now, it's not in its best form, but based on that, it seems to wear out less easily than the Lancer. There are less rattles and squeaks from the suspension and the engine seems sturdier.
    If you really want the Lancer, get one with respectable condition. The Corolla is designed to tackle our bad roads, which explains why its suspension lasts longer than the others. With proper maintenance, the Lancer shouldn't really put you down. It may not be the benchmark, but heck, it boils down to driver preference. So good luck to you.
    Jun 2005
    yung gli98(lovelife), matic ko 13kms/liter sya sa long drive. playing from 80-120kms takbo ok sya compared sa civic lxi97 ko 10-11kms lang..ewan ko kung bakit. benta ko nga lang ulit yung gli ko kasi maliit sya para sakin. consider ko rin lancer eh kaya lang nung nakita ko loob parang plastic itsura. tama ka squala ok talaga suspension ng corolla...reklamo ko sa civic ko nun yung likod pag nalulubak may "TOG" sound eh naka 14inch rim lang ako and 65series tires. ok din shock stopper etc...
    ganun ba talaga honda? kasi pati accord ng kapatid ko ganun din sound.
    check nyo car ko for sale na. gli98 matic.
    My 98 Lxi is doing 14 km/L in long drive with slight traffic. Manila to Bataan. Manila to Batangas. The "TOG" at the rear ound could be caused by worn trailing arm bushing. my car's underchassis still feels very solid, pero me mga pinalitan na din ... like stab links.
    Jun 2005
    wr_castro
    yung lxi ko ok naman mga bushings kasi nung nagpa check ako sa honda quezon ave ang findings nila is shock stopper nga yung parang rubber-stryro sa shocks. di pinalitan nila ganun pa din. tapos medyo naiirita na ako nagtanong nako sa banaue ang sabi nila ganun daw ang honda kasi sa spring na ginamit nila maliit.
    good yung lxi mo kung nakaka 14km/li sana maka tyempo ako ng ganyan katipid.
    peace
    Ang totoo bro ay mas matigas talaga ang spring ng civic kesa ibang sedan, maski maliit ng spring ay medyo stiff naman sya. Kapag medyo worn na din ang shocks mo sa rear makakaramdin din talaga ng ganon. Baka kasi madalas na nag bo-bottom na yung shocks.
    pero ang vote ko ay sa Civic pa din. and cons lang ay medyo mahal ang mga parts nito. pero sulit naman dahil matibay. My 2nd vote would be the Lancer, sorry pero di ko masyado type ang porma ng AE 101.
    Apr 2005
    Only 2 of the 3 cars mentioned ang may firsthand experience ako - Civic and Corolla. The lancer we had was the Gti. If reliability of mitsu made cars is the basis, I'd say OK naman lancer, hindi ka ititirik (xcept nung masira ECU nito). On the build quality, medyo maraming kumalampag sa Lancer GTi within the 6 years the ginamit namin ('92 - early '98) but then again, this is a different horse from the GLXi. Our Civic had 1 minor suspension problem, the corolla had none.
    A friend owns a 1999 GLXi a/t, he's very satisfied with this car, it's fast, economical and sound set-up is amazing (hehe not really part of the car tho).
    Still, If i've to choose, I'd get the CIVIC. hindi po ako bias sa CIVIC, just na mas gusto ko talaga over-all yung model na yun. Para ngang mas gusto ko pa sya than the current model IMHO lang naman po = )
    I personally think the Civic's suspension is softer than the Corolla. It's also lower which is why it drives in a sportier manner. Downside of this though is that it's not as long-lasting as the Toyota's.
    All three cars are nice-looking. Front, I like the Civic, rear, Lancer, everywhere else, Corolla. Choosing through aesthetics is a matter of personal taste.
    Jun 2005
    oo nga ok porma ng civic...kainis lang kasi ginamit na ng mga XLT jeeps yung headlight ng civic maski CRV...corolla naman taxi. ok legroom ng civic pero mas natatatagan ako sa ride ng corolla (bigbody and lovelife). overall corolla talaga ako...kaya lang liit.
    Feb 2005
    mga bro,honda civic vtec pa rin ako.lalo na kung automatic.pag arangkada mo bumabaon ang likod mo sa upuan.parang caprice ss.5.7liter.
    Mar 2004
    civic ka na, with a 300k budget you can even have a 98 civic.go for the vti.nasabi na nila lahat ng advantages ng honda. isa pa, walang hondang ginagawang taxi hehehe.
    i have a 97 civic vti at wala akong problema sa kanya.
    try also looking for cars sa sunday edition ng manila bulletin.magaganda usually ang mga naka-advertise dun.
    ride safely dude.
Help: mitsu glxi 97 vs. civic vti 96 vs corolla gli 95
