Montero/fortuner is bigger, wider and spacious, and clasy than santafe.
swak sa budget mo? you will not go wrong with Montero Sports......not unless you mistakenly stepped on the accelerator pedal instead of the brake
Hell no! The two are not in any way more spacious and classy than the Santa Fe. In fact, I find the Fortuner to have limited seat space and headroom. Although the Fortuner and Montero do have more rear cargo space, as far as I can see. The Santa Fe also has a more comfortable ride, and better on-road handling. And then when it comes to size, a quick look at the dimensions would tell that they are actually not far apart.
specially the monty, pinakamasikip kaya ang montero, sakto lang 3 adults sa 2nd row. ang fortuner sa labas mukhang malaki kaya akala mo maluwag. sa loob, pag nakasakay ka na not so na. comparing the fort and sta fe, yung 4 na aunty ko na medyo plump kasya sa 2nd row ng santa fe. dun sa 2011 fort ng pinsan ko, maluwag sa 3 pero di talaga namin sila mapagkasya na 4. so paano nangyari na mas maluwang ang monty at fort sa santa fe?
the only advantage of the montero sport and fortuner over the santa fe is the ride height and off road capability, everything else the santa fe is much better. montero clasy? :bwahaha: i won't even comment to that.
yun chevy trailblazer kaya...consider mo din TS
gamit ba sa province or dito manila?
if manila SF talaga d'best...
pang province ok na yun monty
2013 Sta Fe! kaso more than 1.8M ata yun? Montero is bound for a new face lift. Nakakasawa na itsura.
Joker si sir.haha. I sat on the montero mas masikip inside compared to the Sorento. Leg Room, Elbow Room, and Head room mas maluwang talaga sorento which is close to SF. The montero looks much bigger looking from the outside, pero the interior space was not.
Sent from my Nexus 7 using Tapatalk 2
I believe the Fortuner is the tightest of the lot. There are compact cars with more legroom and headroom than the Fort.
Santa Fe (1.7M for 4x2) is bigger, wider and spacious, and clasy than Fortuner/Montero (1.5M for 4x4).![]()
