Results 1 to 17 of 17
    Jan 2008
    good day to everybody . just want to get your expert opinion re this matter. Di-d from mitsubishi vs VGT from hyundai.
    1. Which is more advanced/ modern?
    2. more fuel efficient?
    3. how do each one work? both are crdi right?
    4. on the long run which will last longer?
    thanks in advance. sorry medyo bobo ako sa diesel engines.
    May 2005
    AFAIK, VGT (Variable Geometry Turbocharger) refers to a turbo charger and not a proprietary engine technology like Mitsubishi's DI-D or Toyota's D-4D. Pls. see the wikipedia article on VGT.
    Jan 2008
    thank you for the reply but if you were to choose would you choose the one with vgt? thanks
    Quote Originally Posted by zaza.altis View Post
    The longevity, performance, etc. of both engines are almost equal. The Hyundai CRDi engine though produces more HP per displacement and can be chipped to produce even more. Mitsubishi's Di-D on the other hand is the more proven one.
    __________________
    bigbigcar.com First Drive: Hyundai Genesis V6
    Jan 2008
    zaza.altis * VGT is use to eliminate the turbo lag of the engine..as mentioned by mazdamazda Mitsubishi's Di-D on the other hand is the more proven one. Also, adding to that many CRDi engine claim that their engine has the most fuel efficient, but in real world hindi pala.. you can check all the FC's the vehicle you want to purchase. there so many threads here specially the review on fuel consumption.
    Aug 2004
    Well... consider that both the Mitsubishi and the Hyundai 2.5 are based on the venerable Mitsubishi 4D56... Hyundai's CRDi vehicles in the Philippines have proven generally reliable, despite the poor diesel.
    Which two vehicles are you picking between?
    Aug 2004
Diesel engines:  Di-D vs VGT
