Results 1 to 12 of 12
    Aug 2017
    Altis units made in 2008-2012 with the 1ZZ-FE (1.8) or 3ZZ (1.6) seems to have stabilized at the 200-300k mark, I'm looking for a 2nd hand unit for my dad who drives everyday in Manila traffic. His other car is a 2012 Fortuner 2.5 A/T, so automatic is a no-brainer and road comfort is the main priority.
    I've read that the ZZ engine's main issue are high oil consumption due to faulty design in the piston rings in high mileage engines. But I am able to find low mileage Altises (as low as 14K KM reading).
    Are they still a good buy? In terms of maintenance and fuel consumption? Or are there better alternatives now for the money?
    You can opt for a Civic FD 1.8L (2006-2011) instead. I have nothing against the Altis but the Civic FD is as reliable and a better car overall.
    Aug 2017
    I haven't researched much about the FD (but will get into it esp the engine issues soon), but can you give me a few points how it ranks above the Altis for you?
    Quote Originally Posted by leoblack9 View Post
    Maintenance and fuel consumption among compacts like the Civic and Altis are about the same. Interior space is also around the same. However, the Civic FD drives better than the Altis.
    If are looking for something more fuel efficient and still has decent interior space, I suggest you look into the Honda City 1.5L (2009-2013).
    Jul 2013
    no 2 second hand cars are the same...
    so I suggest na piliin mo yung mas maayos na car...
    less mileage, better maintenance and better owner
    Sep 2008
    Wrong post
    The 10th gen Corolla Altis is one of the most comfortable cars in its segment during its time. I personally have a 2009 1.6V A/T, and the ride comfort and NVH/ noise insulation is very satisfactory.
    Performance wise, i suggest you get the 2.0V model, as the 1.6 3ZZ engine struggles quite a bit. Later 3ZR 1.6 units (2010-2012) were quite improved due to the Dual VVTi. The ZZ engines were only used from 2008-early 2010.
    Common issues of this model are the melting dashboard (a number of 10th gen Altis units had their dashboards replaced by Toyota via a silent recall), and the rack and pinion bushing.
    Goodluck on your purchase!
    Quote Originally Posted by ARRESOLIYAT View Post
    You can opt for a Civic FD 1.8L (2006-2011) instead. I have nothing against the Altis but the Civic FD is as reliable and a better car overall. Dafont Showbox Adam4adam
    really!
    how so?
    Troll alert. Kinopya ulit yung prior post ko.
    hindi naman.
    he/she simply re-iterated your opinion, passing it off as his/her own, without citing his/her sources.
    errr...
    naka-walo na. baka puede nang mag-start ng sariling thread.
    SEO bot ata. Trabaho nyan is to sneak in links to raise their page rank. Dapat wag sagutin at lalong lano na wag i-quote it para ma-delete ng buo yung post nila kasama yung links. Nangyari kasi ngayon may nag quote na so kahit tinanggal na ng admin yung original post nya andito pa din sa forum yung links dahil naka quote sa post ibang user.
    I owned an '11 1.6V for five years and here are the issues which every long term owner more or less experienced with that gen corolla:
    1) Ignition coils fail at 40k - 50k kms
    2) replaced rack and pinion and drive column at 30k kms
    3) oil sludge issue (should be ok if owner used fully synthetic oil and changed diligently)
    It was a comfortable car that averaged 7-9 in the city and 10-12 in the highway. Make sure you check the above have been replaced already and also get the 2010 or later versions which have a dual vvti engine.
2008-2012 Corolla Altis 1.8 or 1.6? Good for 2nd hand sedan for the metro?
