2.5L INTERCOOLER TURBO DIESEL ENGINE, 40TKM, FULL TIME 4X4, A/T, DUAL A/C, POWER SUNROOF, 10 SEATER w/ 2ND ROW (FOLDABLE FOOT REST), 4 PANEL POWER BLINDS, 6WAY SOUND SYSTEM, FOG LIGHTS,
NEW TIRES, NEW BATT, NEW T-BELT, NEWLY TUNED AND CHANGED OIL
GENERAL
Body type MV&1Box
Drive FULL 4WD
Transmission EC-AT4 speed
Displacement, cc 2499
Frame KD-SGLR-GJL
Price of new car, thousands yen (Tokyo area) 3057 (~$25400)
SPECIFICATION (SPECS)
EXTERIOR
Exterior dimensions (LxWxH), mm 4585 x 1690 x 1960
Interior dimensions (LxWxH), mm 2815 x 1570 x 1270
Wheel base, mm 2920
Treads (F/R), mm 1465 / 1440
Ground clearance, mm 175
Curb vehicle weight, kg 1840
Seating capacity, persons 8-10
Doors number 4
Min.turning radius, m 5.5
Fuel tank capacity, l 65
ENGINE
Engine model WL-T
Max.power (Net), kw(PS)/rpm 125 ps (91.94 kw) / 4000 rpm
Max.torque(Net), N*m(kg*m)/rpm 30.0 kg*m (294.20 N*m) / 2000 rpm
Power density 14.72
Engine type Water cooling serial 4 cylinder OHC12 valve IC turbo
Fuel system Distribution type fuel injection system (supercharger attaching)
Turbocharger Turbo with intercooler
Fuel type Diesel
Bore, mm 93
Stroke, mm 92
Final gear ratio
Fuel consumption at 100 km/h 10.5km/ltr
Fuel consumption at 60 km/h 8km/ltr
CHASSIS / TRANSMISSION
Power steering Yes
Braking system, front Ventilated disk
Braking system, rear Ventilated disk
Suspension system, front McPherson type
Suspension system, rear 5 link type
EQUIPMENT
EXTERIOR EQUIPMENT
Sunroof / Moonroof Single
Front fog lamp
Rear wiper
Rear or roof spoiler
ABS (Antilock brake system)
LSD (Limited slip differential)
Privacy glass
UV cutting glass
INTERIOR EQUIPMENT
Air conditioner Dual air conditioner
Centralized door lock
at that price mas better specs parin ang delica spacgear 4x4, kahit delica starwagon 4x4 lang mas angat parin kaysa sa friendee. nasabi ko na why sa threads ng frieendee at ody mo.
thanks bro. ewan ko ba bakit bias ako sa friendee. siguro kase nakasakay na ako in one and convenience and appearance-wise, sold ako dito. yun nga lang, wala akong masyadong alam sa sasakyan kaya di ko masabi if ok sya sa performance, safety, gas consumtion, etc.
i need to look around pa i guess. im also considering an ody or space gear, as you have always advised... :groupwave:
remeber, madaya ang friendee, makina katabi mo, not sa front!
and kung usable space lang, spacegear na kunin mo. ung kay alval na naka-ads dito, best buy po yon, 4x2 pero manual, floor-shift. wala ka nang halos hirap sa pagmaintain at piyesa, 90% available na sa market, spacious pa...
kung 4x2 hanap ko lang din, kunin ko yung kanya.
or kung gusto mo forward ko sayo yun isa namng ding spacegear 4wd matic exceed na crystalite, oks din yon, kaso manual 4wd hanap ko, kaya stanby muna. forward ko sayo email nya if interested ka...
