Help mga gurus. i'm panning to upgrade to a reliable SUV in terms of maintenance, FC and availability of parts is concern,
thank you in advance!
^^^ Agree with bro.shadow.
Kung 1 year lang ang difference and this assumes that mileages are about the same, then Pajero FM....
14.8K:cow:
fm for me ........... parang di na luluma ang style kahit itapat sa mga newer model suv di ka mapapa hiya
thank you mga sir!
for the looks ok talaga FM classic! ung fortuner modelo nmn...pero what about sa maintenance mga sir?
and which one got more space, leg room and stuff..
are you looking at the 4x2 model or the 4x4 model for either vehicle?
interior space will not be different between the 4x2 and the 4x4 model but maintenance cost might be
Mas gwapo FM than fortuner...wannabe SUV fortuner made for wannabe Americans...mga asians...![]()
The Pajero FM is still designed as a workhorse in other markets. Compared with the Fortuner, it has more underbody protection (skidplates), the spare tire is mounted high up out of harm's way, etc.
Eariler Pajeros also used a dual fanbelt system for essential engine components (e.g. waterpump) so should one belt snap, the thing will just keep on going. Not sure about the Field Master but this was never offered in the Fortuner.
So far, there are lots of parts for the FM. Even the front fender signal lamps are just Lancer parts. Lots of the interior switchgear are also 'generic' Mitsubishi parts used in other cars.
4x2 vs. 4x4, the only added parts are the transfer case and front axle which just require an annual oil change. So long as you don't bash the 4x4 off-road, they don't break down often aside from a seal or two needing a replacement every decade or so.
Btw, we are selling a 1999 unit. Automatic, 4x4 model. Needs some leatherwork, otherwise, nothing to fix already.
Nothing against the Fortuner, but the Field Master is in a totally different league and was made in a totally different time.
Wow! thank you for all the needed info mga sir! the best talaga kayo...
anyways i'm planning to search/find a FM '03 to '05 4x2 sana,,,
wish me luck mga Gurus!!!
at sir otep PM sent sir...
Go for the Pajero FM, you might want to check out this review made by me - ANYTHING AND EVERYTHING GOES
The Pajero FM? Timeless than most mainstream SUVs
Kahit 4x2 or 4x4 whatever ... FM pa rin ako.
Never matatalo ng Fortuner yan.Magkaiba sila ng level. =))
sir ano po bang ok na model na FM and ano po bang difference nila, sa isat isa?
confused lang po...
