Results 1 to 15 of 15
    Jul 2004
    we are looking for a service vehicle. has to be a workhorse as it will be used to ferry company personnel around and out of manila. most likely there will be lots of travel on the nlex and sctex. no off roading or very rough roads though. the worse road will probably be sand and gravel
    which of these two entry models diesels would be best in terms of durability, fuel economy and low maintenance cost
    In terms of FC, i'd place my bet on the Crosswind. The Mitsu engine is more refined but seems to drink more based on my experience.
    Sep 2004
    In terms of powerplant, both have old but very reliable engines. However, fuel economy goes to the Crosswind since it uses direct injection.
    Also, since you're getting the ten-seater variant, the Adventure's D-pillars slant inward at an odd angle, which means those sitting closest to the rear hatch have poor headroom. This isn't a problem for the seven-seater model, but there's little point in getting it if what you need is a people mover with more seats.
    Apr 2010
    Quote Originally Posted by Bogeyman View Post
    +1 here
    mahirap umupo sa likod lalo na kung malapit ka sa rear door. pag sumakay ako ng adventure FX, as much as possible sa front or middle seat ako uupo, although sikip sya sa middle seat kung apat kayong uupo.
    go for the crosswind xl.
    Jan 2008
    Both have the same seating capacity. FC di naman siguro nagkakalayo, oo sabihin naten direct injection ang crosswind, pero mas reliable at subok na talaga ang 4d56 ng Mitusbishi.
    In my experience, mas matagtag ang ride ng crosswind compared sa adventure. Mas maingay ang makina at parang nakasakay sa Truck. No offense.
    Quote Originally Posted by myas110 View Post
    +1 here
    correct ko lang di naman macocompare ang adventure sa Toyota Tamaraw FX para tawaging "Adventure FX".
    siguro nagkakataon lang na puro advie ang nasasakayan mong PUV, try mo din sumakay sa likod ng crosswind.
    Apr 2010
    Quote Originally Posted by renyot View Post
    what i'm trying to say is the adventure plying as an PUV, sorry if I say Adventure FX. Pero mas maluwag ang crosswind sa likod pag side seats sya.
    syempre lahat na ng AUVs nasakyan ko na (Disclaimer: we used to own a Tamaraw FX)
    Sep 2004
    No question, subok talaga ang 4D56, from the Gen1 Pajero to the L200, L300, and now as the basis for the 2.5L Strada engine. Medyo hassle lang ang palit ng timing belt, compared to the Crosswind which uses timing chain. Although on the other hand, it's a good idea din, since designed ang timing belt na mapalitan at certain intervals to keep the engine running smoothly. Timing chain ideally does not need replacement, but that may lull a lot of people into a false sense of security, which can prove disastrous when the chain does break at a very inopportune moment.
    The Adventure does have a car-like ride; I know mine still does, even after six years of ownership. The models beginning 2004 especially, had their suspension tuned for passenger comfort, unlike the earlier models tuned for cargo transport. And quieter engine too, thanks to the twin balance shaft design first used on the Astron 80. Pero yung fuel consumption ng Crosswind under normal conditions, hirap akong ma-achieve even with religious oil change, shifting at 1500RPM and using biodiesel on the 4D56. Medyo significant ang difference.
    Quote Originally Posted by Flipo
    sir,
    In terms of maintenance economy wise, eg. price of spares and the like, initial price of the vehicle, etc
    which is better?
    Maintenance should be more or less equal since they've both been in the market for so long, although the Adventure can share parts with the L200 and L300. I wouldn't know about the current pricing brand-new, pero six years ago, the Crosswind's asking price was a bit too much, considering what it had to offer compared to the Adventure.
    sir,
    which is better?
adventure GX or crosswind XL
