Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
    Aug 2017
    #21
    Quote Originally Posted by Janemar View Post
    He's reffereing to his subby, akala nya siguro subbie oto mo or what not...
    Anyway, majority of A/T tranny's, it should go to D2 or L/d1 kahit your rolling at speed. Check your owners manual. Baka di mo lang na pindot shift lever button? Anyway, different story pa if papayagan ni TCM/ECM, etc na mag downshift...
    Wala na kasing owner's manual. Sige, will just try again tomorrow Thanks!
    Sent from my EVA-L19 using Tsikot Forums mobile app
    Jul 2016
    #22
    Should be same with your innova 4AT...
    How to Shift Gears in Toyota Fortuner | CarDekho.com - YouTube
    Aug 2017
    #23
    Thanks! Appreciate it.
    just know if your brake pads and drum shoes need replacing...
    #25
    Quote Originally Posted by playplugg View Post
    Thank you very much Sirs dito sa mga replies dito sa topic thread na-open ko, really appreciated at really helpful.
    Hindi lang po sa akin pero sa lahat ng readers dito sa forum..
    BTW:
    Honest question po ito?
    Yung mga EBP ba in-case of ultimate emergency, pwede ba ito gamitin to stop? even lahat ng illumination dun sa panel na disabled lahat ng ABS/EBD?
    Pwede po ba natin ito i-brake ang sasakyan?
    Safest way to brake is to just step on the pedal firmly. Modern braking systems are designed to let ABS and EBD take over during panic braking situations - all you need to do is press that pedal hard.
    For more experienced drivers, you can apply threshold braking - the point where braking power is at its maximum without trigerring ABS. Takes a while to get used to but it's very useful on the track.
    Oct 2017
    #26
    Let's make it more complicated pa! Haha
    You can play with your car's balance. You can shift the weight around when you brake.
    For example, just before you go over a hump, depress the pedal to shift the car's weight to the rear, thus for a smoother entry over the hump.
    Lol! 😂😂😂
    Sent from my SM-G930F using Tsikot Forums mobile app
    #27
    Lol! 😂😂😂
    Depress means tapakan, so your weight will shift forward when you step on the brakes, not backward. 😊
    Oct 2017
    #28
    Sorry, what i meant was lift your brake pedal for a smoother entry sa hump. Hahaha
    Basta apak brake, yun na yun. Lol
    Mar 2004
    #29
    Still confusing ... lifting your foot off the brake pedal is different from stepping on the brake pedal ...
    #30
    I dont get this thread. [emoji16]
    Aug 2017
    #31
    SUCCESS! 😂 tried to put in L when going downhill.
    Oct 2017
    #32
    Sorry.
    Lift off the pedal before you hit the hump para weight ng car nasa likod na. Thus, less suspension action (ang intense neto) sa front.
    #33
    CVT ba, once na override into manual mode, effective ba ang engine braking?
    #34
    Yup. I use L mode all the time on my Civic whenever I go down from Baguio to capitalize on engine braking.
    Jan 2009
    #35
    If a bump or pothole gets you by surprise and there's not enough distance to brake to a full stop, firmly step on the brakes anyway to bleed off as much speed as possible and let go just before you hit the bump/pothole. That will usually prevent or lessen suspension and wheel damage.
    That said, you should only do it if there's nobody tailgating you. If it's a trailer truck, forget it! You stand a better chance just running over the bump/pothole than to get rear-ended with solid steel.
    Then there's also those rare potholes that you can practically "skip" or fly over when going fast enough. Braking in this case, might even be detrimental. Experience will teach you which road imperfections requires you to slow down and which ones can be taken at a faster speed.
    What you do depends on your environment.
    Jul 2012
    #36
    pano naman po malaman kung nag-engage ABS? may indicator ba yun? or mararamdam sa behavior ng oto?
    Jan 2009
    #37
    Quote Originally Posted by enzo6k View Post
    You'll feel pulsations from your brake pedal accompanied by a distinct "KRRRRRRRG" sound from the ABS motor.
    Some cars will flash their brake lights (or 3rd brake light) to alert the drivers behind that you're trying to do an abrupt stop.
    Mar 2004
    #38
    Brake light flashing usually indicates Brake Assist is activated ...
    Jan 2009
    #39
    That would be more accurate. Thanks
    Jul 2012
    #40
    ah nice thanks i haven't experienced ABS yet, good to know in advance, baka kasi bigla ako magpanic pag naramdaman ko hehe
Braking Capabilities..
