helloif you gonna buy a AUV,sino po pipiliin nyo for your comfort and fit para sa araw araw nyong gamit,interms of for long time use?
sorry di ko type ang XUV/Sportivo eh... nakita mo na ba crosswind XTi? check mo sa dealer sir then compare mo sa Adventure GLS Sport. but between the two 100% sa XTi ako.
sir bakit po xti? and ayaw nyo sa XUV? kasi parang oks naman tindig ng XUV,mataas at macho compare sa XTi...tell naman po bakit mas okay yun XTi to enlighten me...
thanks![]()
Like I mentioned in your other thread, with the same engine displacement and pagdating sa power to weight ration iiwanan ng XTi even ang top of the line Sportivo esp the a/t. Siguro kung 2.8li ang nilagay nila sa XUV and Sportivo. But if you really inclined to the XUV/Sportivo it’s up to you because it’s soooo slow. Maporma lang but….hanggang dun lang.
Test drive mo sir. I suggest unahin mo Isuzu (XTi and XUV/Spotivo) then the Adventure GLS. Feel the difference in acceleration![]()
Pero kung ang dadaanan mo lagi ay off-road. Go for the Crosswind XUV na.....
Okay naman ang XUV eh, basta makaya mo lang ang bagal niya sa acceleration
Masyadong maliit ang Advie pang off-road or business......XUV ka na.......
Pero diba ang Xwind, overpriced na rin?
korek ka dyan sir,ang mahal ng crosswind, compare sa adventure, but still im giving his a chance kung worth it nga kung gano sya kamahal compare sa adventure.![]()
Why not just buy a Strada DiD? starts at 855k only. Very good crash ratings in Europe and USA, proven engine block. No chokes whatsoever. Very fast, nice ride too. It's very decent to be used as an office car or a business vehicle.
The Santa Fe CRDI VGT which I immersed in windshield deep flood (Araneta Ave) never had a problem for 3yrs already so this fear of common-rail is unfounded (except if you're gonna choose a Toyota D-4D which is kind of a lotteryor worse, Isuzu 4JX1 <trooper '03>).
If we're gonna submit to the premise to buy only proven stuffs, then we'll never progress into the next generation of technology. We'd be stuck driving around steam engined cars.
We had a water-in-fuel scenario back then (here in manila of all places!!!) but all you have to is drain the fuel filter by loosening a little nut (its plug). That's it. After the water is gone, it'll go as if nothing happened again. It will not be damaged because when the computer senses that there's water, it will warn you through the instrument cluster panel (where the speedo is) and it will not go beyond 60kmh. Since you'll get used to driving at 160kmh around manila, you'll definitely notice that.
If I were you, I'd get a Strada 2.5 or a Montero Sport 2.5 (though for the MS, I would've prefered a 5MT than a 4AT).
Carens is a very good choice too. Kind of sayang though kung pang-business since it's very nice.
Anyway, good luck.
ganun talaga pag proven na and reliable payou know when i get my XTO (top of the line 'to in '01 ha?
) pinaka mura siya compared to Adventure and Revo but now kita mo? you know what i mean.
it's very cheap to maintain. 4 liters of oil every 4-5K kms, replacement filters (air, oil and fuel) cost around 200 each, it has a separate water separator so you can drain it as often as you want, FC at 12.+ kms/li on the manual tranny. then saan ka pa?
and i agree with HP, if you can afford the 1M++ carens, why not consider the faster and also reliable Mitsu DI-Ds Strada and Montero Sport 4X2? konti nalang dagdag mo.
good luck and wag magmadali![]()
