Results 1 to 20 of 25
    Aug 2013
    I'm planning to purchase a car for my wife on september. 3gen Toyota Vios 1.3E M/t ang plano ko... kaya lang, my wife wants the 2014 mirage GLS.
    Mas mababa ang FC daw kasi, mura lang (Php588,000), may GPS/DVD HU with controls * steering wheel, ABS/EBD, RISE, automatic climate control, dual airbags at push-start/stop button.
    Kaya lang, may hard-starting problem yata ang mirage (sabi nila, affected lang daw ang AT... hindi ang MT)...
    May nabibili na ba na GPS/DVD HU for the new 3gen vios... how much?
    Any comments...
    Aug 2013
    Any comments...
    Meron naman mabibili basta kaya 2din head unit. If I were in your shoes, ill fight for the vios since it's bigger overall and I like Toyota in general. Ok din Mirage but it's smaller and wala masyado space sa trunk.
    the mirage is smaller, but is more loaded and has better consumption. and its brand new.
    although for me, the durability of toyota would tell that the vios would be a better choice.
    besides, may trunk space sya.
    Aug 2013
    Kung si misis gagamit I would let her decide para walang sisihan.
    Pero kung hindi para kay misis at walang ibang kotse, sa Vios ako. Pero kung meron nang primary vehicle, Mirage para tipid sa gas (kung di lang delikado sa daan motorsiklo na lang para mas tipid).
    Sent from my mind using Telepathy 2
    Aug 2013
    Quote Originally Posted by denden042203 View Post
    Any comments...
    What about on the NEW hyundai accent? They changed their engine to Kappa dual CVT engine coupled in 6-speed transmission. Is this ok?
    Dec 2012
    Vios. Only reason id pick a mirage over it is budget.
    Jul 2010
    Any comments...
    since bago pa vios baka wala ka pa makuha na frame para sa 2din HU as replacement sa factory installed.
    mirage is OK in terms of FC space etc...(as what you mentioned) yung current CVT models lang ang may issue sa starter pero lahat naman na naka encounter ay pinapalitan. aside from the starter issue panalo ka sa mirage kung daily drive lang ang purpose though you can use it for out of town trips. may palabas na mirage this coming sept yung sedan model aside from the current hatchback.
    I've just purchased my vios 3 weeks ago, i also try and browse from mitsubishi i've seen the gls model and its loaded and more cheaper, but its a little bit smaller, and after asking for suggestion from people, most of them recommend me to go with vios, if i were you according to some comments let your wife to decide so nobody to blame in the future.
    Aug 2013
    Any comments...
    What about the NEW Hyundai Accent M/t? They changed their engine to Kappa dual-CVT engine coupled to 6-speed transmission. Is this car ok?
    I would definitely get the Vios, I really trust Toyota plus the new Vios is gorgeous. It's bigger than a mirage pa.
    Oct 2005
    Any comments...
    I would definitely go for the Vios. I have a Mirage GLS CVT. Initial ownership is quite a nightmare. Although OK na kotse ko, nakakapika lang sa simula knowing you bought a brand new 'problem'. Now, I have to keep my car casa-maintained cos they said pag bumalik daw yung sakit ng oto at hindi casa maintained, they won't be honoring any of my claims. Di ba bullsh!t?
    Isa pa, the refinement of Vios is head and shoulders above the Mirage. Ang lakas mag vibrate ng engine ng Mirage. Pansinin nyo wipers ng mga Mirage na katabi nyo while naka-idle. Yung wiper arm kitang kita malakas mag vibrate. Plus the ride of the Vios is better although the Mirage is good naman. Mas OK lang talaga Vios.
    In fairness to the Mirage, it is really fuel efficient naman talaga and got punch when you need it and feature packed.
    Goodluck.
    Jul 2006
    Quote Originally Posted by basti08 View Post
    That is because its a 3 banger. 3 bangers are terribly unbanlanced engines. Manufacturers would mask this deficiency by installing a myriad of balance shafts, counter weights, extra heavy flywheels, etc.
    But still ..........
    Sorry to burst the Mirage bubble, I think its a great car. If only MMC shoved a proper 4 banger in there.
    Oct 2005
    Any odd cylindered engine (3 & 5cyls) actually. It is a matter of tuning and refining lang siguro. Volvo 5 cyl engines are kinda smooth (based on an 06 S60 2.0T experience). They say the 1.0L Ecoboost 3 cyl is also smooth and vibration-free. But the Mirage's engine is left that way siguro to keep the cost low.
    Jul 2006
    5 bangers would be smoother because of bulk/metal mass. Vis-a-vis, technically, one cannot design a 3 cylinder engine using 5 cylinder technology (general) di ba? The manufacturers can only do so much in a 3 banger scenario under the "controlled conditions" of an R&D facility.
    But its different in real world conditions.
    Sep 2004
    That's because according to Ford, they deliberately unbalanced the flywheel to offset the shaking forces commonly associated with 3-cylinder engines.
    Sep 2013
    ..... Ang lakas mag vibrate ng engine ng Mirage. Pansinin nyo wipers ng mga Mirage na katabi nyo while naka-idle. Yung wiper arm kitang kita malakas mag vibrate. Plus the ride of the Vios is better although the Mirage is good naman. Mas OK lang talaga Vios.
    Ang vios gen2 pansin ko medyo malakas din ang vibrate pagnaka idle ito lalo na kung hot ang weather. bagong linis lang naman ang throttle valve at MAF. Sa inyo ganun din ba or isolated case lang ba ito? Sabi naman ng casa normal lang naman daw yun basta ang idle ay hwag lang below 600rpm. sabi pa ng casa ang vios ay walang counter weights para minimize ang vibrate ng engine unlike sa camry. Tutuo ba kaya ang sabi ng casa???
    Oct 2005
    Quote Originally Posted by kimbon View Post
    Wala naman ako naranasan na ganyan sa gen 2 ko dati. Actually aside sa aux fan at slipping belt sound. Wala naman ako complain. It's an almost problem free car.
    Jul 2006
    I would only feel vibration in our Vios when its time to clean the MAF and the TB. Otherwise, its just gas and go.
    Sep 2013
    one time nga sumakay ako ng taxi. naitanong ko kay mamang driver kung may feel syang malakas na vibrating sa engine. sabi nya wala din naman. It's true nga naman wala kong na feel while on d road from NAIA heading home, nasa front passenger side pa nga ang pwesto ko. Baka naman car ko lang kaya ang may ganitong medyo malakas na vibrating sa engine huh.
3Gen Toyota Vios 1.3E M/t VS 2014 Mitsubishi Mirage 1.2 GLS M/t
