If you want better performance than the 1.8, the RS is the way to go. Fuel consumption won't be that bad compared to the 1.8, since it's an MT... when my car was stock, it could get 7-8 km/l in the city... even up to 10 km/l on weekends when the traffic was light... and 12-16 km/l on the highway when driven at 80-100 km/h. (16 was on the NLEX, two hour trip up north)
Reliability is okay compared to other cars of the time. There doesn't seem to be a single common thread to problems with the car's electronics. (In other words, the specter of sure cam position sensor failure as with the 1.6 doesn't seem to exist). The only common issues seen on stock RSs is a dirty IACV and PCV system that can cause rough idling, but these are easy to replace and fix.
When test-driving an RS, these are the things to look out for:
Quality of the idle.
Clunking from the suspension (this is true of
any secondhand Japanese compact... and the Ford Lynx RS
is a Japanese car).
Oil and coolant condition and level (again, true of
any secondhand Japanese compact).
Crunching into 3rd gear (signals that 3rd gear synchro is wearing out and may need to be replaced soon. Part is cheap, but you have to order it from the US.)
Shuddering on clutch application (sign of a warped flywheel or a glazed clutch).
The last two problems can be signs of abuse, so they will tell you how the owner drove the car and you can ask for discounts accordingly or look at a fresher unit.
The only big reliability problems with RSs we've encountered have been with guys with modified units that have been abused.... 300+ hp turbo-builds can blow the engine up
and if you engine-brake it to 7000 rpm on the race-track or drive it at 220 km/h for half-an-hour straight... or every single day, you can blow it up.
Guess what? You can blow up a Civic, too, if you drive like an idiot. The only difference is that a K20 Civic can be turbo-boosted to silly levels.
My car has been on the track, drank half-a-liter of oil driving at over 6000 rpm on the NLEX and SCTEX... straight... topping out at 225 km/h for five kilometers or so... has been on the dyno numerous times... has been run on LPG at over 160 km/h... has run lean at times when I messed up the LPG and Unichip maps (I've been experimenting with it...) and has been "enjoyed" to death for over 97k kms. My compression is still good, and when we cracked open the head for port-and-polishing a few months ago, my gaskets were still okay and my pistons and valves were spotless. My car is proof that you
can abuse the car and it will still stay alive as long as you change the oil regularly and follow proper warm-up and cool-down procedures. Of course, I've destroyed clutches, ruined brakes and had to rebuild third gear... but if you drive on the racetrack and drive hard like I do, you can expect these things to break. My previous car, a Sentra, broke a drive-axle on the drag-strip. That's how hard my cars' lives are.
If all you're going to do is drive around the city and occassionally wring it out to 220 km/h on the NLEX, there's no issues.
For the Civic, in addition to the suspension and oil/coolant, check to see if it was included in the cam position sensor and gas tank recalls, and if it was, if those fixes have been done, already.
Also check for rust. Older Civics were notorious for rust, and I'm getting some scattered reports that it can happen on newer ones, also.
Do note: if either of these cars have accident damage, rust can form, so check for thick spots in the metal or weirdness in the paint surface that may indicate crash damage. I've not noted a propensity to rust in the Lynx, but it can happen with the sunroof panel, since the steel frame of the sunroof glass isn't treated as well as the rest of the car. The frame-rails of the sunroof, though, are aluminum and immune to rust, and the body steel around the sunroof is well-protected and insulated.
The RS is much more fun to drive than the Civic. Only issue is that driving it in traffic can be a pain sometimes, since it's a manual. It looks great as stock and all the dress up you need is often a bigger set of wheels. The Lynx can actually fit up to 19" of wheels with the right off-set, and many tuners use 18's as everyday wheels. Only dress-up needed on the inside is leather seat covers and a better head-unit.
