Page 1 of 3 123 LastLast
Results 1 to 20 of 44
    Guys need your help! Is this a good deal? I'll be adding 50k cash for the swap.
    Vios 2010 1.3E
    -150k mileage
    -some minor issues like
    Civic 2006 1.8S
    -68k mileage
    -sobrang kinis
    -zero kalampag
    -all stock as in lahat halos walang ginalaw
    Assuming na macheck namin yun civic at in a very good condition talaga to. Good deal na po ba ito?
    TIA sa inputs mga tsikoteers!
    Quote Originally Posted by zel.chikot View Post
    Vios 2010 1.3E
    -150k mileage
    Civic 2006 1.8S
    -68k mileage
    -sobrang kinis
    -zero kalampag
    you are giving away your vios + 50K, in exchange for the civic?
    looks good, assuming everything is as stated.
    Market value of the 2010 Vios E = 350,000
    Market value of the 2006 FD = 350,000
    ok na yung deal considering swap. ang tanong ko lang is bakit gusto mag maliit na sasakyan nung may-ari ng Civic? and siguraduhin mo na walang problema yung oto. check for leaks, transmission, suspension, etc.
    Yes sir assuming na in very good condition talaga yun fd like what it looks sa pictures, sa mileage and sa description ni seller. Btw mag dadala din naman ako ng marunong tumingin. Is it as easy, or a bit comparable, to maintain an FD as it was on a vios? Kasi as we all know sobrang dali magmaintain ng vios given the abundance of parts at nagkalat kahit saang auto shop.
    Btw thanks sir sa reply!
    Apr 2016
    Vios 2010 1.3E
    -150k mileage
    Civic 2006 1.8S
    -68k mileage
    -sobrang kinis
    -zero kalampag
    The civic is older. So I am expecting it may need more maintenance done to it, I may be wrong. Maybe if you can do a straight swap instead of adding 50k then that would be a better deal for you. I wonder what the RFS is? That is what I'm more worried about.
    Quote Originally Posted by 1D4LV View Post
    Sir bale +50k po ako. I decided to throw in this amount dahil sobrang kinis nung unit at low mileage po yun fd. Yun vios ko naman may issues like high mileage, na wash over na din, may konti pang kalampag (for replacement shocks and shock mounts I think)
    Good deal na po ba ito if ever? Thanks sa reply sir
    i read that this civic"s engine support breaks down at regular, frequent intervals..
    Just triple check the FD. Confirm service records (to ascertain mileage) and ensure the vehicle is not flooded.
    Per olx, A 2010 1.3E Vios would have a sale value of around 250K-300K while the FD is also around 300-350K.
    Per experience, the Vios takes abuse better then the FD. On a 2010 model Civic I maintained, it had the PS hose break down at 40,000kms, and the engine mounts, drive belt bearings and wheel bearings needed replacement at 65K kms. It's not that expensive to replace though so okay lang. Just annoying. Our 2007 Vios on the other hand has 135,000kms on the odo and so far i've only replaced shocks and the wheel bearings (and this unit took a swim in Ondoy).
    But of course, in terms of driving experience, the FD is much more engaging.
    Quote Originally Posted by Turbo Diesel View Post
    Yes sir ito nga din yun pinagiisipan ko. Papalitan ko yun kotse ko ng mas luma. Pero given na mataas na yun mileage ng car ko, at dream car ko naman noon itong fd, is it worth the swap? Yun low mileage at allstock +never repainted daw yun unit e yun yung nakakuha ng attention ko para magoffer sa kanya iswap vios.
    No. I won't swap my sedan for another sedan that's older than 4 years. If it's an SUV or CUV pwede pa
    Isa nga din ito sir sa nakita kong issues with this model. at 40k eh palitin na ang engine support nya.
    Oh wow! I've had ZERO repairs on my 2010 Altis since I bought it. Just the regular PMS. It still runs like new (except for the kalampag when I changed all the tires)
    Another reason to love Toyota
    Tama sir. Sa vios ko pinakamahal ko palang napalitan is clutch assembly at yun underchassis parts like tie-rod, stab link, brakes, repack ng CV joint, gear oil. Di pa nga ako nakakapagpalit ng shocks at shock mounts pero to follow na sana. Wala din naman sa plano ibenta yun vios pero rare opportunity para sakin ito kasi I wanted an FD before pero napunta kami sa vios way back 2010. Ngayon nakachamba ng low mileage(assuming hindi tampered, gotta check the condition ng car compared sa mileage pag navisit na namin) kaya gusto ko sana iswap yun vios kasi mataas na yun mileage nya.
    Thanks sa inputs ma'am! Ito din naghohold back sakin, isswap ko yun car ko sa mas luma. Kaya humingi ako ng tulong sa tsikoteers kung okay ba na igrab ko tong deal. Mag add ako ng 50k for a low mileage car, magiging fd pa yun car ko. Planning on buying mags sana at repairs ng vios. Pero dumating itong civic at pumayag na for swap sa vios +50k, dun ko nalang ilalagay yun pera na pang repair at pambili ng mags hehe.
    Mura-mura lang Ninang engine support
    If you still can haggle to lower the 50k out of pocket. Baka Kasi Meron leak Yan R&P just to cover for the repair just in case.
    Nov 2016
    For me, I will triple check the car before I can say it is a rare opportunity or a great deal.
    It is a 10-year old car na din. I am sure there are for replacements. So better save up for this also.
    Jul 2006
    I second that.
    Quote Originally Posted by RR_22 View Post
    Actually sir nanggaling to sa 70k. Sabi ko hanggang 50k lang kaya ko ishell out. Hanggang after a week nagconfirm siya sa 50k. May mga issues din kasi vios sir na wala ipapagawa ko pa sana pero kung papayag siya na as is na yun vios then add ako 50k much better for me assuming na in very good condition talaga yun fd pag nakita namin. Given the conditions, wil it be a good deal na mga sir? Thanks!
    I second that.
    Agree ako dito sir. In 6 years ng vios sakin, walang naging major problem. Parang tangke ika nga. Everyday workhorse tapos no major issues so far. Currently at 150k odo.
    kabait mo dude. masyado mataas cash out mo, imho. para sa akin, around 30k will do to cover cost of repairs for your vios.
Swapping my Vios 2010 1.3E for 2006 Civic FD 1.8S
