Page 3 of 3 FirstFirst 123
Results 41 to 50 of 50
    Apr 2008
    #41
    The 1st gen Vios is very cramped, though fuel efficiency is known to be very good. It is a 1.3 after all.
    If mostly used alone, as a daily commuter car I'd go for it. If with passengers, I'd go with the Altis.
    Sent from my SM-G900I using Tapatalk
    Jul 2018
    #42
    He's buying a 2nd hand altis. Di natin alam history. Prone pa naman sa engine sludge itong engine ng altis.
    yes po 2nd hand lang kasi kaya ng budget
    Sent from my SM-J730G using Tapatalk
    Apr 2008
    #43
    Quote Originally Posted by cripto View Post
    Magkano ang budget? Personally I have nothing against the Altis. Hindi naman magkakasludge if oil changes were done regularly. Just bring a mechanic. ES Civic, ayaw?
    Jul 2018
    #44
    Quote Originally Posted by GTi View Post
    180k sir to 200k sir. yan lang vios at altis na pupusuan ko
    Jun 2005
    #45
    Vios na. Pagkaalala ko notorious sa sludge build up yang 1.6 altis kapag di napalitan ang oil sa tamang oras.
    Pareho lang naman ang altis at vios engine of that era... Parehong sludge prone
    Sent from my MI MAX 2 using Tapatalk
    #46
    if it were me pag iisipan ko between the altis space and the convinience of the AT ng vios. kun may altis na matic sana sa choices dun ako.
    Jan 2008
    #47
    We have the 2002 altis with already 180k kms. Regular change oil at 5k kms. Had the oil pan and valve cover resealed at 170k kms and found no significant sludge build up.
    Only issue i have now is the rack and pinion.. medyo may alog/ingay na kahit new rack ends and tie rod.. sabi ng aking mekanik eh wag na muna galawin kasi wala naman leak. Hehe sayang daw baka tumulo lang pag ni repair pa
    Jul 2018
    #48
    mas malaki ba sir space ng altis kaysa vios?
    Jun 2013
    #49
    Oo mas malaki ang altis. Subcompact ang vios, compact class na ang altis.
    #50
    mga boss buhayin ko tong thread vios 1.3 vs altis 1.6
    need to ng advice mga sir between 2003 vios 1.3 vs 2002 altis 1.6 parehas slang m.t 2nd car wla ako masyado idea sa 2car n mention ko at 1st car ko pa lang kung sakali alin kaya mga sir best sa dalwa?
    that vios is masikip.
    that altis is not as masikip, but masikip just the same.
    that vios will give more km/li than that altis.
    fit your body inside them, to compare, and see if you can live with it.
2014 models : toyota altis 1.6e mt vs vios 1.3e at
