Originally Posted by
d_mac
Is it the 2.5 TBz or 2.8 you've pushed hard? I know how V6 gasoline ones are chief, in fact i have one, a Grand Vitara 2.7 MFi 4x4. Also, not all turbocharged petrol-feds maintain their peak torque throughout the rev-range; the Subaru Forester 2.5 turbocharged, for one, feels a bit sluggish from bottom-up when you floor the pedal, not so in the case of V6 of course, since there are more sequential up-and-down strokes to cover a cycle.
However, there are lots of diesel fed out there that maintain their peak flat torque over broad rev-range, to name a few amongst the 4-cylinder e.g., Toyota Fortuner 3.0 D-4D at 343 Nm from 1400 to 3200 rpm, 2012 Philippine-issue Fortuner 2.5 D-4D at 343 Nm from 1400 to 2400 rpm, Toyota Prado ar 410 Nm from 1600 to 3000 rpm, Philippine-issue Isuzu Alterra at 294 Nm from 1400 to 3400 rpm (same thing goes to its D-max equivalent), Thai-spec Alterra (MU-7) at 360 Nm from 1800 to 2800 rpm, new Isuzu D-max at 380 Nm from 1800 to 3000 rpm, perhaps even the Santa Fe 2.2 R-eVGT may qualify, rated at 437 Nm from 1750 rpm to 2500 rpm.... lemme also include the 5-inline Ranger 3.2 TDCi rated at 470 Nm beginning 1500 to 3000 rpm, where 95% of that 470 Nm is already tappable by 1200 rpm.... How much more the straight 6 and V6 diesel feds, coming from BMW, Mercedes-Benz, Renault-Nissan, Volkswagen, VM Motori etc?
Practicality-wise though, if that is the primary question of the thread-starter, a 4-cylinder diesel-fed SUV like the Trailblazer 2.8 that is already producing a peak 470 Nm torque at such a relatively low-rev of 2000 rpm (compared to a gas-fed, more so a V6 one) sipping way less fuel for even a higher torque. 90% of that 470 Nm on the TBz is already available by 1700 rpm. The peak torque on the TBz starts to dwindle gently down-dip past 2000 rpm, BUT it does not dive drastically as the ones you see in a Monterosport 3.2 Di-D, and or the Navara 2.5 with the high-power YD25TTi engine. It's a different story on the peak torque of the all-new Ranger 3.2 5-inline though as it is broad, and 470 Nm is 103 Nm more than the CX-9's that is seeping more fuel and needing to rev way higher. Inherently also, even commercial ones, diesel engines have higher compression ratios (16.5 to 17.9 : 1) compared to their petrol-fed counterparts/ and equivalent-displacements (around 9.5 to 10.5 : 1) that's why even at low revs they make more power and torque....
Certainly, i won't need a V6 gasoline-fed that is only producing 367 Nm torque if i'm after practicality/ functionality/ and after a responsive engine, Won't need one that is seeping way more fuel and just because by virtue of having the ability to rev way higher than diesels engines, YET producing lesser torque, they are able to achieve 277 hp. But that's just me though....
Cheers chief!
