The GTV Monty is only stronger than the 3.0-litre Forty at screaming revs of 4000 rpm, because it can rev-out further.
The 3.0-litre Forty's 1KD-FTV is not designed to be an ultimate revver but rather as a well-packaged engine that caters very broadly all throughout its useable powerband even from a low rev of 1400 rpm. It's already giving out a meaty 343 Nm of torque even when it's only doing a total of 700 times per minute pressure combustion at 1400 rpm engine-radial speed
(rpm) since it's a 4-stroke diesel engine ---- i.e. a cycle of 1 pressure combustion for every two-revolution of the crank. Pressure combustion is in sequence for each of the 4-cylinders that are connected in 90-degree throws along the crank.
The GTV Monty is NEVER EVER faster at all than the 3.0-litre Forty even when the latter is just a 4-speed tranny. Kindly see below sir.
Mas maganda pa rin sir ang gear ratios/ spacings ng 3.0-litre Forty kaysa Monty GTV, and it is faster. This is an excerpt on what i have posted at Toyota Forum in one of the past threads thereat. Hey, you were there nga pala sir! Haha! ;)
Now if you gentlemen are still in doubt, kindly go to the Engine and Fuel System Talk and click onto the last page of the sticky thread dedicated to Racechip Pro. There's a fine gentleman out there with a modded GTV Montysport and he stated in there that he's making 100 kph at 2000 rpm.
http://tsikot.com/forums/engine-fuel...05/index9.html
Ngunit sa dalawang yan mas mabilis pa rin at low-revving ang 2.2-litre Santa Fe R-eVGT sa dalawa. At 2000 rpm the 4x2 Fe is speeding 112 kph, while the 4x4 is speeding at 112.3 kph. In fact it is running 190 kph even when it's only revving 3392 rpm.
