please help me to choose and which branch can I best purchase it... thanks in advance.
kung 1 or 2 lang ang typical na sakay. OK ang vios para matipid sa gas. pero kung kailangan mong magasakay ng 5 or more kadalasan, Avanza na.
typically 1 or 2 lang ang sakay sa avanza ko. kaso pag mga out of towns. hindi kami kakasya sa sedan. so avanza ang binili ko. pang pamilya.
punta ka sa pinakamalapit na mga toyota casa. mag request ka ng quote. get at least 3 different quotes from different dealerships to get the best deal.
i believe the vios rides and drives more comfortably. but the avanza can carry more loads. what do you prioritize?
avanza ako kasi mas spacious siya. you'll never know when you'll need that extra space![]()
avanza ako, it is better to have additional people/cargo space when you need it...
vios? tingnan mo mga taxi na vios, open mga hood nila, may tendency na mag-overheat pag long use...
ako naman vios. hehe
kung family of 3 or single ok vios. practical, easy on the wallet. more comfortable than avanza.
yung avanza naman tipong loader type. hindi ko lang trip handling and comfort level. pero kung maramihan lagi, avanza na.
That's because the car is driven 24/7 with only eating, peeing and napping as their only breaks. And usually, operators use water instead of coolant. Which I think, a private owner wouldn't do.
*TS : If you'd carry 3-4 passengers, a vios would do. Even it's 5, still, i`d go for the Vios. It's faster, more maneuverable and classier, compared to the Avanza obviously. And, it rides softer than your other choice. May pagkamatagtag ang avanza and with it's narrow body tendency is when you attack the curves at a somewhat high-speed, baka umikot yan.
Yknow, thin tires and a narrow body should not go on with each other.
Test drive them both.
Vios ako...
Yung Avanza parang masyadong malata eh... Not a place I want to be in a crash...
Vios for me.
You get power features, driver airbag, a safer and much more modern body structure, modern dashboard.
The Avanza may have bigger space but space in the Vios isn't so bad either.
