Results 11 to 20 of 63
February 9th, 2007 07:48 PM #11
February 9th, 2007 09:22 PM #12
In terms of comfort, design, handling...etc. Innova gets my vote.
In terms of diesel, I cannot totally recommend the D-4D engine of the Innova bec. nobody is really sure if Toyota solved the earlier problems already.
February 11th, 2007 03:43 AM #15
Sir Hintayin nyo na lng po ang release ng bagong Mitsubishi Zinger. Due 1st Qrt. ng 2007.
February 11th, 2007 01:41 PM #16
Fuel efficiency and durability, the Crosswind is pretty good.
Quality isn't so, though... American-cheap plastics, flat seats and poor structural rigidity and noise insulation... don't get an AT, as they're slow as molasses. The MT may not be much faster, but with the end of the exhaust and radiator problems with the new upgrades, there's not much that can go wrong with it.
It's a horribly stiff, noisy and smoky car, though. Don't spend too much money on the top-of-the-line version. Better to get a mid-level model with just enough amenities (as long as it has power windows, it's okay.)
The Innova is the most comfortable, easiest to drive and quickest. It also has decent fuel economy with either engine (although decent for a 2 liter gas vehicle this big isn't very good compared to the diesel).
The "D4D woes" thing might be an issue if you have no high-end "boutique" gas stations in the province, but if you've got at least a major Shell or Petron station there, it shouldn't be much of an issue. According to larshell, the reprogramming apparently works, so newer D4Ds shouldn't be affected by the problem.
If it's a worry, you can always get the gas version. It's quieter and more refined than any of the other choices you've given.Last edited by niky; February 11th, 2007 at 01:43 PM.
February 12th, 2007 01:08 PM #17
overall ill pick the adventure, meron kami ung 2005 grandsport and sobrang ok, utility vehicle na comfy and have good entertainment system saka eto na ata pinakamura dun sa tatlo
- Jan 2007
- 9
February 12th, 2007 03:12 PM #18Crosswind!
The company service vehicle here is closing near its 600k kilometer already!. I believe na kaya talaga umabot talaga ng makina neto to the Isuzu's claim of 1million kilometer service.
matibay na ang makina, matibay pa ang underchassis.
Have you tried comparing the specs? Did you ever wondered why its Curb (GVW) weight is almost 500kg more than the innova which at aroung 1,600 kg only? Hmmm..
Driver/PasaHERO
- 1,310
February 12th, 2007 06:15 PM #19we're also buying a family car within the next 3 months. We're currently looking for a diesel powered utility vehicle. Adventure GLS 2.5L Diesel sells at 840K+ while the top of the line crosswind(manual) i think sells for 970K. We're leaning towards the Adventure mainly because of the price and we noticed that the 130K price difference is only because of the amenities(LCD, rear sensor, etc). Do we have other options aside from the two? Innova is out of the choices(my dad doesn't like the styling haha)
February 12th, 2007 06:27 PM #20
Innova VVTi... (don't get me started with the D4D woes issue :rofl01
The Crosswind & Adventure pales in comparison in terms of comfort / refinement and on-road performance. Simply put, the Crosswind & Adventure needs a replacement ASAP to compete properly.
But if you are only shopping for a diesel fed MPV, tough luck mate... I wouldn't recommend anything really at this point.
high idle RPM at engine start
