Page 4 of 5 FirstFirst 12345 LastLast
Results 61 to 80 of 133
    Jul 2018
    No owner's manual and service record? ... Pass ... Service record is very important ... There are a lot of other cars with for sale ... Find one with complete records ... Don't rush ...
    Yes po. Thank you.
    Jan 2013
    We're you able to check and see the original OR and CR or just a photocopy? Kung photocopy lang pinapakita nila sayo and to follow na lang daw ang orig... Mahirap yan sir.
    Sent from my ONEPLUS A3000 using Tapatalk
    Jul 2018
    Quote Originally Posted by remzam View Post
    They showed me original OR/CR po plus yung TPL insurance. They just renewed the car registration last 06/18/2018. I took photo of them.
    Oct 2016
    Hi guys. May titignan akong civic fd 1.8s 2008. 79k mileage. Any specific na titignan sa unit? Shocks,tranny,etc?
    Quote Originally Posted by Jmkl View Post
    Engine supports, ask owner when did he do ATF change, suspension (shocks, stab links), aircon, power steering, radiator.
    maintenance records?
    when was the last ac-oil change done? mahal compressor.
    napalitan na starter? battery changed? age of tires - nasa sidewall. look at the throttle body kung malinis. pcv napalitan? spark plugs? ignition coils? spare tire. water pump napalitan? thermostat napalitan? coolant is water lng or premix?
    test drive, note how car response to humps. how fast the ac cools. brake pedal feel.
    Oct 2016
    Thanks for this. Considering lahat po yan papalitan, magkano kaya aabutin?
    Oct 2016
    Another question pala guys. If civic 1.8s fd 2008 yung bibilhin ko, how would it be compared sa crv 1st/2nd gen if considering the fc. Baka kasi same lang halos sa fd yung fc, baka mas ok yun kasi mataas ground clearance. Nadagdagan nanaman ng choices hayy
    Apr 2008
    Syempre mas malakas ang konsumo ng CRV kumpara sa FD 1.8, pero kung FD 2.0, hindi nagkakalayo. However, kung manual na CRV kinuha mo, baka mas magiging sulit. Pero yung 2nd gen na "ten cheater" na kunin mo para sulit talaga.
    Sent from my SM-G900I using Tapatalk
    Quote Originally Posted by GTi View Post
    That 2nd gen "ten-cheater" CRV is not that fuel efficient. A former colleague used to drive a 2.0L AT version of that "ten cheater" and he was only getting 5 km/L on metro manila traffic.
    i like that term.
    how many of us are old enough to remember why...
    i like that term.
    I guess it has to do with how Honda declared the category of that model of the CRV. It was placed in the category of an AUV instead of a CUV.
    Apr 2008
    The ten cheater AT was notoriously bad. But the MT seems to be significantly better. Worth consideration?
    Not much difference in terms of fuel consumption between AT and MT models. The K20 engine offers decent power for a 2.0L NA engine but it is not known for fuel efficiency. Accords, Civics, and CRVs powered by the K20 had a reputation for being not that thrift on gas.
    Apr 2008
    double post
    Oct 2016
    Hi guys may nakita nakong 1.3s na city 2009 matic 64km. Medyo fresh, may konting scratch lang sa likod. And isang civic 2008 1.8s matic 73km naka matte finish and spoilers, 17 na mags pero 2nd owner. Any comments guys? Baka itong 2 na final choices ko
    i am not attracted to matte finish, and some spoilers (yung matataas) remind me of pushcarts. i prefer all stock. but that's just me.
    other than that, and assuming both are in good condition, i prefer the civic. i find it more comfortable.
    just make sure the documents are in order, especially that second owner.
    i would be curious, why they are for sale.
    errr... magkano sila?
    Oct 2016
    Actually mataas spoiler nung civic hahaha. Both reason nila is maguupgrade "daw" . 310k both binibigay nila. May cash na kasi ako and gusto ko na talagang bumili. Required pa ba sir na ipa-LTO yung OR CR or DOS lang then pa notaryo lang ok na?
    notarized deed of sale.
    plus, chpg (old name!) clearance. yung macro-etching, to insure "no negative history of the car".
    and original CR. xerox copy only adds extra legwork kasi. not impossible, just more legwork.
    if 2nd owner still hasn't transfered ownership to his name, make sure all documents of sale from 1st owner to 2nd owner, are in order and are original. check the IDs. they should be up to date (daw). hihingin po ng lto yan.
    marami po diyan na hindi pa na-transfer ang ownership sa kanilang pangalan. if documents are complete, it shouldn't be a problem. but i have a negative point to those who do not transfer ownership..
    Bro i assumed aside from outer, sana you checl also the maintenance component, check if okay ba engine, aircon and etc. me also,i prefer all stock, rims upgrade depende if gusto ko ang design... hehe goodluck.
Need help 300-400k budget
