Wow. EK never dies haha
Sent from my F3216 using Tsikot Forums mobile app
^ hindi naman. Matipid nga iyong ph16 ko dati. Bulletproof pa basta wag lang pabayaan mag overheat
when you look into the abyss, the abyss looks into you
Paano po ba mprevent magoverheat ang car sir? Medyo takot ako sa akyatan eh kasi natatakot ako magoverheat. Di tuloy ako makaakyat sa tagaytay.
Check Radiator. Kung nababawasan ang tubig or kulay kalawang ang tubig pa overhaul mo lang radiator around 700 pesos.
Check Water pump. Youtube mo nalang. heheb
Check engine. Pa check mo sa mechanic mo kung ok pa cylinder head.
Check Thermostat. Kung meron.
sa akin kasi ever since hindi pa nag overheat. I use nga pala antirust coolant mix with distilled water.
Sent from my LG-H870DS using Tsikot Forums mobile app
Ah ganun pala. Wala pa kasi ako alam sa sasakyan. Gumagamit lang ako hehe. Salamat sir. Ill take on this po. Ang turo lang kasi sakin ay tingnan kung may tubig.
^ wag basta basta tubig. Dapat gamitan mo na ng premixed coolant para iwas sakit ulo
Mga sir any idea about my honda civic 99 vtec ph16 sir look kasi automatic siya pero ang problema is pag nilagay mo sa P R D wala ilaw sa gauge na naka indicate peeo pag nilagay mo sa neutral e nasa P naman nakatapat yun ilaw sa gauge ano po kaya ang gagawin dun
Sent from my A37f using Tsikot Forums mobile app
If your budget can go up to 190k, you have much better options. One would be the Mazda 3 (2004-2010). prices usually hover at 200-220k but sometimes you'll see them going for around 190k. It's a more modern car. Also, maporma din. Pwede pang binata
I've had several 6th gen civics (1996-2000). They feel very dated already, especially the interior. They're older cars so reliability is questionable. Honda power steering systems are prone to failing. The 7th gen civic (2000-2005) looks too similar to the previous model and the interior also feels dated.
If you're a younger, guy i would recommend the mazda 3. It looks sporty and it feels very modern. Plus even if you get a 2004 model, it looks like the 2010 model so hindi masyadong mukhang luma. If you're the office guy type, the altis could also be a good option. It's a toyota so it should be a bit more reliable. It's also more fuel efficient
Here's a video tour of my 2005 mazda 3 which i sold a couple of months ago for just 210k. 1st gen 2 5 mazda 3 review, full-tour "charcoal" - YouTube
For a comparison, here's my 2003 Honda Civic: my 7th gen Honda Civic dimension body "Lightning mcqueen" walk around/full tour/review - YouTube
