Results 1 to 10 of 10
    May 2011
    Mga sir ask ko lang sa inyo alin kaya sa dalawa ang best buy? starex grx (07) 810K from buy & sell or urvan estate (09) worth 898K private seller, both manual transmission..
    nakakalito po which one to choice, primary purpose is for family use and pwedeng business like van for rent.. first car po kasi kung loloobin, bale consider narin po natin ung cost ng magiging maintenance cost...maraming salamat po..
    Aug 2009
    Cost of maintenance-Urvan ako.
    Kung sa mga rent a van, mas madalas nilang ginagamit yung urvan. Correct me if i'm wrong. Kung pang family use, sa starex ako. Kung ako kasi pipili, sa starex ako. Why? Kasi mas comfortable para saakin yung starex and adequate yung power niya compared sa urvan.
    Apr 2008
    Without a doubt, the Starex is the better van. The Urvan is lacking in power (105ps/213Nm vs 145ps/360Nm for the Starex). And the engine is a 3.0L unit so fuel efficiency isn't going to be great. Kung Urvan ang kukunin, dun na ako sa JDM unit which comes with an intercooler turbo version of the local Urvan Estate's engine and dual sliding doors.
    May 2011
    Thanks Sir GTI and Sir Sleepcare, actually po ung mag fi-finance yung brother in law ko na japanesse, at first binigyan ko sya ng pics ng toyota grandia at urvan escapade at ung grx model ng starex (note second hand lang po ung kukunin), reply sakin ng bayaw ko want nya ma-try Starex ng Korea dahil parang nauumay na daw sya sa japanese made car, ironic nga nagtatarabaho sya sa Honda engineering, to make it short kaya sinama ko parin sa choices yung Urvan Estate dahil un nga rin ang purpose para narin sa kahit "van for hire", every 3months kasi nauwi sya dito lagi kami umaarkila ng Van, mahilig kasi mamasyal bayaw ko, if I were go to Starex yung maintenance cost ang iniisip ko, ..anyway salamat po ng marami uli...
    Aug 2009
    Ahh i see. Wala kang pag-sisisi sa starex. Just make sure na magandang unit makukuha mo.
    Apr 2008
    Kung ganun eh di Starex na talaga. Especially since ang Urvan dito is leagues behind the one sold in Japan. He will just keep commenting on how bad it is. Just as long as you get a well maintained unit and maintain in well yourself, then it should serve you well.
    Aug 2004
    Scrutinize both units carefully before buying. If one of them was a former rent-a-van, there are chances that it could be "laspag". Inspect and test-drive both before deciding. Don't rely on odometer evidence in making your decision.
    Quote Originally Posted by GTi View Post
    A GRX Starex TCi can only churn out 100HP max.... 145HP is for the Starex CRDi.....
    13.1K:bike:
    Quote Originally Posted by MacGyver1 View Post
    Starex na nga, financed naman pala, kaya mo maintenance niya. Sulit na yan IMO. Ganda niyan, in all aspect ha!
    Apr 2008
    Ang Starex GRX may CRDi and Turbo Intercooler versions. Kung Turbo Intercooler ang nakita na GRX ng TS, siguradong hindi aabot ng 810k ang presyo.
Best buy between Starex (GRX - 2007) and Urvan estate (2009)
