Page 2 of 2 FirstFirst 12
Results 21 to 40 of 44
  1. #1
    Quote Originally Posted by zechs
    at which handyman store did you find the flashband? coz my bro went to RP manila handyman, and its not available(?) or they dont carry it? not sure.
    Saw some Flashband available in True Value ATC.
    Oct 2003
    hmmm makapunta nga sa ace hardware kung meron..
    Oct 2003
    ang P400 mas maliit yan. hindi yan ang 4 inch wide x 10 meter long
    Feb 2005
    Honga eh nagulat ako sa presyo kasi parang price yan ng 50mm x 10m. I just mine for P680 100mm x 10m ito yung 4 inches! Bukas ko pa to install!
    pagbalik ko from kids vacation, DIY ako... thanks ILD
    Oct 2003
    hey gonna revitalize this thread!
    Im planning on dynamatting my 2nd Gen CRV from what I've read. Only all four doors though cause I have no problem with engine noise.
    I have set up my sound system and noticed that there is only this thin plastic on the doors with white goo. Do you think dynamat would make a big difference on just the four doors, or at least something noticeable?
    Mar 2005
    Quote Originally Posted by Hero33
    If your going to use Dynamat Extreme on your doors it will eliminate the rattling noise and also it will improve the sound quality of your speakers if you have one installed. Please let me know where did you buy or dynamat and how much does it cost?
    Oct 2003
    I'm planning on trying Mickey's Audio when they open hehe
    I dont notice any rattling much so do you think it will make a difference in ambient sounds in the car?
    Mar 2005
    Yes, it will make a difference if you are going to install Dynamat on your doors. For more information just visit the link below.
    http://www.dynamat.com/car_faq.htm
    Q: Why do I need a Speaker Kit?
    A: In your car, applying Dynamat to the flimsy sheet metal surrounding your speakers eliminates speaker panel distortion. Dynamat also stops vibration rattles and squeaks.
    Sep 2004
    using dynamat makes the doors heavier tama ba?
    Feb 2005
    Ano kaya ang effect kung yung egg tray ang porma ng foam. Tawag nila nito sa Mandau Foam eh Profile foam raw. Eto raw yung gamit ng mga maliliit na recording studios mura lang. Di ko lang alam kung ano effect nito sa vibration ng mga trunk or door panels and sa effect na rin sa quality ng sounds ng oto mo. Tried using ordinary foam na medyo makapalt before pero walang effect sa pag control ng vibration. Di ko lang alam kung itong Profile foam is mas effective. Sana may makasubok mura lang naman ang special cut. Yun 4 feet by 5 feet is only 750 petot ang special cutting! Try niyo naman then kindly give your feedback!
    Oct 2003
    6pack,
    the effect of foam is for sound absorption. if u wanted to eliminate or minimize the rattling on ur trunk, you need to add mass or weight to the metal sheet by applying a deadener like flashband or dynamat. i could be wrong with the foam but this is just my opinion.
    Feb 2005
    Yeah tama ka wingman as per your advise already added flashband after sa eb namin nila Doy. But before niyan na try ko na yung foam thou not this profile acoustic foam. Pero ok na ang unit ko di na gaanong maingay unlike nung di pa ako naka Flashband. lalo na nung ma seal ko na yung mga butas kanina ahehehehe!
    mga sir, panu pag hindi ka nag ssound setup? pwede pa rin ba lagyan ng sound deadening ung sidings?
    tadtadin lang ng sound deadening materials para tunog euro pag sara ng pinto and less road noise :D
    Mar 2005
    Quote Originally Posted by odell
    Salamat Odell sa iyong suwestiyon. linagyan ku lang ng ilang flashbond yung pinto na aking sasakyan at na alis na yung kalambag pero medyo bumigat ng kaunti yung pinto dahil sa flashband.
    Jun 2006
    Revive ko lang tong thread.
    Want to sound deaden my 2 front doors, for sound system improvement. Anong shop ko pwede ipagawa at ano dapat ang budget? Don't want to DIY, tamad ako and dont know how to remove my door panels.
    Dont care about brand. Flashband is ok, generic US brands are also fine with me. Just want to improve my midbass and lessen noise.
    TIA
    cheapest that i asked is araneta car accessories. yung kay jefftan.1200 ata per door. check kotseaudioclub.com for his contact number na lang. flashband gamit niya
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    Does flasbanding the trunk lid really help with the rattles? I like bumping the bass, but, I dont like to bump it too much, because I know, on the outside people hear rattle rattle rattle! Percentage-wise, how much of the rattle can be diminished? I also might deaded the side walls, my power antenna stopped working due to probably the bass rattling the mechanism.
    Jun 2006
    Quote Originally Posted by caloyski5 View Post
    Thank you sir. Got in touch with him. He charges 900 per door labor and material. Ok ba workmanship nila? And how many layers of flashband is needed? Some people say 1 layer is enough others 2 layers. Alin kaya ang tama?
What kind of sound deadening material that you can recommend?
