Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Nov 2007
    I'm planning to setup for SQ for now no amplifier at subs muna. Ang headunit na balak ko ikabit is Pioneer DEH-7950UB. At sa speakers separate component. Ano marerecommend nyo na package component speaker? Budget mga 20k para sa speaker. Mga 16-17cm ang size ng woofer/midrange/midbass. Tpos ung tweeter kahit anong size. 2-way/3-way. Thank you in advance for your response.
    Aug 2004
    ganda din for sq yung bagong focal polyglass vr.
    Nov 2007
    ah ic, thanks sir! stupid question cguro to pero...kailangan pa ba ng amplifier? o kaya na ng HU un?
    Aug 2004
    maganda sensitivity ng focal polyglass 165vr kaya pwede naman i-drive ito ng HU lang. pero syempre mas gaganda ang tunog nito if you use a good amplifier.
    Nov 2007
    thanks for helping me choose a speaker.
    Aug 2006
    elates or the iridiums good in SQ!!! plus genisis P2Ultra amps good combos!!!
    Oct 2007
    get mo high-end amp para swabeng-swabe ang tunog ng focal or morel mo.
    Aug 2006
    butler??? DLS TA2 series??? Focal FP DM??? JL audio300/4???Sinfoni 100.2 SPX
    http://ampguts.realmofexcursion.com/...2/outside1.jpg
    http://ampguts.realmofexcursion.com/...0/outside1.jpg
    http://ampguts.realmofexcursion.com/...r/outside1.jpg
    http://ampguts.realmofexcursion.com/...4/outside3.jpg
    http://ampguts.realmofexcursion.com/...X/outside1.jpg
    DLS TA2
    Hybrid 2 channel tube amp.
    Output Power at 13.8V, 20Hz ∼ 20kHz and <0.1% THD:
    2 x 100W * 4 ohms
    2 x 200W * 2 ohms
    THD: <0.04% (1 Watt)
    Freq. Response: 10Hz ∼ 50kHz (±0.5dB)
    S/N Ratio: >102dBA
    Damping Factor: >240
    Tube: 2 x CV4010 (VALVE Electronics)
    Butler TDB2150
    TubeDriver Blue
    2 x 150W * 4 ohms
    1 x 500W * 4 ohms bridged
    Fuse: 2 x 25A
    Focal FP Dual Monitor
    2 x 300W * 4 ohms
    2 x 400W * 2 ohms
    1 x 800W * 4 ohms bridged
    1 x 1200W * 2 ohms bridged
    . 2 internal DSP 24-bit/96kHz 180 mips.
    . Burr-Brown op-amps
    . Triple Darlington Toshiba 5000 output stage
    . Crystal 24-bit/96kHz converters
    . Coaxial and optical inputs
    . Digital graphic eq 30 band 1/3 octave
    . External digital control from a PC with USB port
    JL Audio 300/4
    Output Power at 11V to 14.5V:
    4 x 75W * 1.5 to 4 ohms
    2 x 150W * 3 to 8 ohms bridged
    THD: <0.03% * 4 ohms, 20Hz to 20KHz at rated power
    S/N Ratio: >108.5 dB below rated power (A-weighted, 20Hz - 20kHz noise bandwidth)
    Frequency Response: 5Hz - 30kHz (+0, -1dB)
    Damping Factor (50Hz): >200 * 4 ohms / >100 * 2 ohms
    Nakamichi PA-2004
    4 x 100w * 4 ohms
    4 x 200w * 2 ohms
    2 x 400w * 4 ohms bridged
    Precision Power DCX1000.4
    4 x 125W * 4 ohms
    4 x 250W * 2 ohms
    2 x 500W * 4 ohms bridged
    Sinfoni Edition Shadow 100.2 SPX
    Output Power at 12V:
    2 x 125W * 4 ohms
    2 x 220W * 2 ohms
    2 x 370W * 1 ohm
    1 x 460W * 4 ohms bridged
    1 x 770W * 2 ohms bridged
    THD: 0.01%
    S/N Ratio: >90 dB
    Freq. Response: 10Hz ∼ 3 kHz (+/- 1dB)
    Current Draw: 116A (* max output)
    Aug 2006
    ngeee nag double post sorry mods bat nauna pa yung post ko kesa sa quoted post ni hammerdin???
    Aug 2006
    Quote Originally Posted by hammerdin View Post
    di mo na kelangan ng rearfills. pagandahin mo na lang ang [SIZE="5"]front staging [/SIZE]mo although maganda na yan dahil sa focals mo.you can use stock rear speakers powered by HU.
    anong focal seps ba gagamitan? BE??? anong ride mo?
    yep, X2 ako kay hammerdin!!! you can forget about the rear fills and place your extra funds on a nice decent amp nalang
    either Focal,JL,genies or the sinfoni!!!
    last IASCA SQ champ uses a DLS iridiums together with a sinfoni amps!!!
    May 2007
    Pioneer 7950UB din HU ko. Ang gamit kong seps yung Morel Dotech Ovation 6. Maganda ang SQ as far as i'm concerned. Nakakabit nga lang ito sa amp.
    Here are the specs of the seps:
    [SIZE=2]Nominal Impedance[/SIZE][SIZE=2] - 4 Ohm[/SIZE]
    [SIZE=2]Power Handling - [/SIZE][SIZE=2]140W[/SIZE]
    [SIZE=2]Max. Transient Power Handling - [/SIZE][SIZE=2]500W[/SIZE]
    [SIZE=2]Sensitivity (2.83V/1M) - [/SIZE][SIZE=2]90dB[/SIZE]
    [SIZE=2]Frequency Response [/SIZE][SIZE=2]- 40-22000Hz[/SIZE]
    [SIZE=2]Crossover Point - [/SIZE][SIZE=2]3200Hz 6dB/octave[/SIZE]
    [SIZE=2]Voice Coil Diameter
    Woofer: [/SIZE][SIZE=2] 54mm (2.10")[/SIZE]
    [SIZE=2]Tweeter: [/SIZE][SIZE=2]28mm (1.10") [/SIZE]
    [SIZE=2]Voice Coil Wire
    Woofer:[/SIZE][SIZE=2] Hexatech Aluminum[/SIZE]
    [SIZE=2] Tweeter: [/SIZE][SIZE=2]Copper [/SIZE]
    [SIZE=2]Magnet System
    Woofer: [/SIZE][SIZE=2] Double ferrite rear vented[/SIZE]
    [SIZE=2] Tweeter:[/SIZE][SIZE=2] Neodymium [/SIZE]
    [SIZE=2]Mounting Depth
    Woofer: [/SIZE][SIZE=2]61mm (2.40")[/SIZE]
    [SIZE=2] Tweeter:[/SIZE][SIZE=2] 20mm (0.8")
    [/SIZE]
    Nov 2007
    thanks toolightz! nde kaya sobra sa power ng mga amps na yan? ang balak ko na final setup para SQ is 1 set seps sa front(under 20k) then tapos isang low power sub, at 1 set ng rear speakers(under 20k), pero nde ko pa na-pagdedesisyonan kung anong klaseng speaker ang ilalagay ko sa rear. ano sa tingin nyo ok na ba para sa simpleng SQ lng, basta swabe lng ang tunog?
    Oct 2007
    di mo na kelangan ng rearfills. pagandahin mo na lang ang front staging mo although maganda na yan dahil sa focals mo.you can use stock rear speakers powered by HU.
    Nov 2007
    Quote Originally Posted by toolightz View Post
    ano ung "BE"? ride is FJ40. about the rear fills, wla kc stock speakers sa likod, lagyan ko pa kaya ng speaker?
    Quote Originally Posted by forxcrawler View Post
    I think he's referring to the top of the line seps ng Focal. Utopia BE to be exact Nasa 6 digits ata SRP nito
    Pag under 20k na seps sa focal, go for the VR Nasa 16500 - 17500 ito a few months ago when I was scouting for seps ;)
    Jun 2007
    tipid meal na SQ goodness targa seps + mb quart crossover tangalin nalang yung built in ng targa
    pero kung kaya talaga ng budget no doubt focals + high end amps
    May 2007
    If you really into SQ and looking for component speakers that gives you WARM, TEXTURED SOUND and SUPERB STEREO IMAGING that you'll hear every nuance of the music, go with POLKAUDIO SR series(Model #SR6500 or SR250)
    Aug 2006
    Quote Originally Posted by MyDestiny View Post
    nice go with the VR's
    Nov 2007
    i went with 165VR for seps, i'm satisfied with the speaker! astig, SQ talaga! thanks sa inyo. still thinking if i'm gonna add a 8" sub and amp for sub and seps, costly cla. ok lng kaya to go budget or just save money and go high end?
    Aug 2004
    mas gaganda pa ang tunog ng focal vr if you have an amp. for the sub naman i suggest you choose 10" or 12" para hindi ka bitin sa bass.
What component Speaker will you recommend for simple SQ setup?
