Results 1 to 3 of 3
    Aug 2007
    hi po sa inyong lahat!!!
    my tanong po ako, ano po ba ang mas magandang sub na bilin one L7 na 12" o two CVR na 12"???
    *** CVR two 12" ***
    sa amp po daw sabi sakin dalawang amp daw mas maganda kung sa CVR na two 12" thunder audio daw gamitin, ano po ba mas magnda thunder o V12 ba un not sure??how much nmn po ung mga un?? at gano karami watt na dapat hanipin ko sa amp nun??
    ***L7 one 12" ***
    sa L7 na 12" nmn po what amp na pwede mapagana ang L7 na mabuti??thunder audio pa din po ba o V12?? at ilng amp po dapat?? at ilang watt dapat?
    ang car ko pa is mazda 323F(1999 model) my alternator is 65A nakalagay dun, kakayanin po ba nun ng alternator ko one L7 12" or two CVR 12"?
    ang batt ko nmn po is in good condition pa po....
    or kailangan ko pa po magpalit ng alternator and batt??
    gusto ko po kasi ung bumabayo na setup
    budget is 25k po..........
    my HU na po ako na deh-p3950mp tapos sa harap na speakers is Pioneer TS-A1682S 6" 4Way 280W tapos sa likod pioneer 6"9 po na stock...
    i just need a sub and amp lang po...
    alin sa mga sub po ang magnda..
    tnx po sa mga reply....
    Jul 2006
    Quote Originally Posted by wicked_jester View Post
    *** CVR two 12" ***
    ***L7 one 12" ***
    Sir, for a 25k budget, it's pretty short for an american made Kicker L7 IMO. Be reminded that it has high power requirement which means upgrading your battery as not to compromise any other electrical dependent part/equipment installed in your car. There are lots of cheap L7s out there but be reminded that these copies won't perform as good as the original. You can/may even get a solobaric L7 copy from china for only 3,500. But take note, your ears might get damaged due to the inconsistencies and sound waves it produces. I think L7s are priced at around 13,500-15,000 php at any store nowadays, and pairing it up with a decent amp which may cost more than the sub itself will at least fetch 10,000 up. Korean V12s are ok, but I have feedbacks from friends who use them that they aren't that reliable specially since they are just... copies. Thunder Audio, is your best bet.
    About, CompVRs, they are great on a non-port box. And, a decent stereo amp (2 channel) will do, It's logical for a 25k budget to not buy two when you can/may get one.
    And having two different amps, will help your setup more complicated. Say the need for a proper tuning for an additional crossover and rewiring for a Y-connection for this, additional expenses.
    Go for the CompVRs, also consider the space of your putting in your setup. If you go for a L7, you need at least the whole trunk (if you have one).
    HTH!
    Aug 2006
    why not try other brands like Digital Designs? www.ddaudio.com
    512=7,4++
    ported box=1,5++
    Jackhammer audio
    9 Queensville st., Whiteplains,QC
    Contact person Jack 09178235225
what to choose one L7 12" or two CVR 12"
