Results 11 to 13 of 13
- Aug 2013
- 22
July 20th, 2014 09:42 AM #11salamat sa mga inputs mga sir. ineenjoy ko na tweeter ko.. sulit na sulit ganda ng sounds..
July 20th, 2014 11:22 PM #12
4khz for a tweeter? That's pretty high. Most tweeters can play comfortable 3.2khz upwards on a moderate volume level with the more engineered ones going lower especially large-format tweeters which has a more robust voice coil and magnet structure.
The higher your tweeter HPF, the "safer" it is for the driver.
Red_one presented a good post. However, I will remind car audio folks that the only time you damage your speakers - whatever driver it may be is when you drive past its mechanical limits. That's only the direct cause of damage - the others are simply causal relationship. For example, give a subwoofer a 10W clipped frequency, it won't even be damaged even if the waveform has a lot of energy inside. Why? Because the voice coil can take the punishment.On the otherhand, a tweeter with its smallish 1" VC won't.Last edited by jhnkvn; July 20th, 2014 at 11:32 PM.
- Jul 2008
- 10
July 21st, 2014 09:40 AM #13
Xiaomi E-Car
