Results 1 to 13 of 13
    Feb 2007
    kng lagyan mu ng mas malaking ampir ung amplifier anu mangyari? bibigay ba ng malaking volt?
  2. #2
    Nope, it is a safety feature. If there is a surge of voltage that goes thru the amplifier, more than it is designed to take, then it is the fuse's job to cut off the power supply so that the amplifier won't be damaged.
    Think of it this way, it is like a circuit breaker for the amplifier.
    Aug 2005
    Quote Originally Posted by maddox09 View Post
    The fuse is for protection of your electricals outside of the Amp.
    Kung ang amp mo ay gumagamit ng 10 Amp na fuse, wag papalitan ng mas mataas na fuse dahil baka ma baliwala ang protection na binibigay ng fuse.
    Ang fuse ay may current rating na puwedeng dumaan sa kanya. pag lumagpas ka rito iyong fusible material nya ay matutunaw and then mapuputol.
    Jun 2006
    The fuse is there to protect your amp. Its designed to be the weak link in the electrical system and blow in case of short circuit or electrical problems. Simplest explanation is its there to sacrifice itself and thus saving your amp from damage.
    Don't change it to a higher rated fuse. It might not blow and your amp will be toast. :electricf:
  5. #5
    wala pang gumagamit ng automatic circuit-breaker sa mga auto,e...kaya fuse lang.. bakit kaya????
  6. #6
    AW: mas bulky ang circuit break and more expensive.
    Jun 2006
    I know they also sell circuit breakers for cars. Saw some a long time ago. It is more expensive than fuses.
    BTW, make sure you install a properly rated fuse or breaker within 18 inches of your battery. Its to protect your car incase your power cable going to your amp gets damaged.
    merun na akong nakita na small versions ng circuit breakers...ga botones lang...parang P30-50 a piece .... hindi ko lang alam kung anong voltage and amperage ang rating nun.
    Quote Originally Posted by alwayz_yummy View Post
    There are some vehicles with circuit breakers. Nissan Patrols use them for their power windows.
    The breakers reset themselves after they trip and are not accessible without taking the dash apart.
    Mar 2005
    These types of breakers are thermally operated in the same way thermostat does. They reset themselves when the temperature reduced below the tripping point.
whats the use of the fuse in the amp? give more volt?
