Results 1 to 6 of 6
Tsikot Member Rank 4
- Jun 2006
- 2,605
March 31st, 2007 05:53 PM #1Saan pwede mag pa fine tune? Hopefully in QC. Ok naman yung setup pero di ko makuha yung tamang tono. Medyo nakaka fatiuge ng tenga.
April 1st, 2007 08:21 AM #2
Sa pinag set apan mo bro dapat tune na nila yan. if you want try mo din kay jeff tan sa may araneta. agahan mo lang kasi dami nagpapagawa dun.
- Jun 2006
- 2,605
April 1st, 2007 10:28 AM #3Thanks. The store that set it up tried to tune it. Pero di ko type yung pagtono nila. Mas ok nung pinalitan ko. Pero di ko makuha ng tama.
I heared A+ Audio does level matching, is this true? If, yes can someone give me their contact number.
- Aug 2006
- 1
May 31st, 2007 08:50 PM #4Bro. may built-in crossover filter switch ba ang ampli mo? ung set-up mo ng sound system mo? 2 speaker system plus 1 subwoofer ( bridge mode ) ba? if your answer is YES !!! maybe i can share some idea to you and sa mga tsikoters..bro. 1st step tsek mo muna ang crossover filter switch ng amplifier mo, make sure na nasa LPF (low pass filter) at set mo sa ON ung switch na para sa sub, next ung 2 speakers mo naman make sure na nasa HPF (high pass filter) then set mo rin sa ON ung switch..If every thing is set..Ok now let start boogy, sa sub muna tayo slowly adjust mo ung input Level Controller ng LPF until wala ka ng marinig na voice sa sub mo..then sa 2 speakers mo naman adjust mo rin slowly ung input level controller ng HPF until mawala na ung base sa mga speakers mo..kung satisfy ka na sa adjustment mo..now timplahin mo na ngayon sa HU and EQ mo ung gusto mong boom boom at kalansing ng sound system mo. I hope my suggestion will help you..
- Apr 2006
- 27
June 9th, 2007 07:44 PM #5tama sab ni zanc, recommended ko rin Jeff Tan ng Car Accessories sa may araneta ave dun din ako bumili ng f2500.
June 9th, 2007 08:31 PM #6
basta make sure yung maganda sa pandinig mo ang lalabas pag na tune na system mo. sana bago mo pinatapos magtune yung naglagay ng sysyem mo e pinakinggan mo muna para pag labas ng auto mo, ok na agad!
Xiaomi E-Car
