Results 1 to 6 of 6
December 20th, 2006 08:19 PM #1
when i listen to my sound system and honk my horn, i hear a sharp TIK sound. any recommendations/troubleshooting tips on removing the sound? naawa ako sa tweeters ko e
December 21st, 2006 07:08 AM #2
buti nga sayo sakin subwoofer ang tumutunog. pero ngayon nawala.. minsan lumalabas. ano kaya cause nito?
December 21st, 2006 08:46 AM #3
mas ok nga subwoofer e, mas tolerated ng sub yung sound kesa sa tweeter
Driver/PasaHERO
- 1,310
December 21st, 2006 02:26 PM #4d kaya mejo may tama ung mga wires na ginamit either sa horn or sa speakers?
December 21st, 2006 06:04 PM #5
Stock pa ba yung busina? Ok lang tunog?
As a first step, I'd clean the contact points of the horn button and relay, baka madumi na. Poor contact, large current can cause that kind of interference. You may also want to check if the fuse is firmly seated in its socket.
December 21st, 2006 11:24 PM #6
i doubt the cause to be in the audio system
noticed it when i replaced my stebel magnums for the fiamm "nfl" horns. i added a relay na nakarekta sa battery.
thanks thanks. will inspect wiring of the horns again
i wouldn't. and neither will the majority, probably. pagawa ko na lang when the need arises. the...
Mitsubishi Xforce
