Results 1 to 8 of 8
November 22nd, 2007 01:34 PM #1
hi! newbie here. may i ask what are the things or materials needed to amplify the front and rear speakers of ae92? especially the wirings needed. plano kong i-DIY. meron na akong amplifier rockford fosgate punch 200a.
tiy
November 22nd, 2007 01:49 PM #4
rca cable.
external fuse for the amp(if ever wala).
afaik 200 is a 2ch amp(i maybe wrongh though). so yung harap mo lang pwede amplify. but dont worry, some audio fanatic amplify only their front speakers at rear fill na lang yung likod.hth
November 22nd, 2007 02:00 PM #6
monster cable(pricey). just look sa mga electronic shops. kung saan fit ang budget dun na.
Tsikot Member Rank 4
- Jun 2006
- 2,605
November 22nd, 2007 03:28 PM #7Amp
rca cable
power cable min 10 guage
ground wire same thickness as power cable
remote wire
speaker wire around 12 guage
amp rack
waterproof fuse holder and fuse - kabit mo within 12 inches of the battery. You need this even if your amp is equipped with onboard fuse. This is to protect your car, not your amp.
November 27th, 2007 02:24 AM #8
if budjet constrains bili ka nalang ng kit kay C3 audio
doonkami nakakuha noon 1.6k
incudes:
5mtrs rca
2 pcs G8 power wires (Neg and pos)
1 fuse block( 1 g4 in/2g8 out)
1 power spliter (for 2 amps)
g12 speaker wires
power terminals
high idle RPM at engine start
