Results 1 to 11 of 11
    i need a small radio tuner, maybe half the size of a regualr 1-din HU? is there such a thing? i wonder what HU they use for those radio equiped motorcycles/UB/scooter....
    Yung sa kakilala ko parang generic Discman ang gamit. ang cute nga may maliit na amps din pala pang-motor. hehehe.
    Btw, saw your Trooper sa review center kanina.
    otep, pano yung hook-up ng speakers?doable ba sa samurai w/ 4 speakers? ang plan ko kasi is to install a small radio tuner then mp3 via fm tuner, medyo limited kasi yung space sa samurai. Almost everyday nandun ako, sometimes sa loob ako naka park....
    Feb 2004
    i don't know of any 1/2 din or any smaller than 1din sized headunit in the market today. what the motorcycle peeps are using are portable players like discmans, mp3 players, etc.
    as for your audio system install for your samurai, drop me a line and let's discuss options. i'm sure i can think of a way to put in a decent system in your ride. click on the link in my signature for some samples of my work.
    Jan 2004
    Creative makes MP3 players with radio tuners. There might be an adapter for a 12v/13.8v source, add a LOC to wire it to a small amp under the seat if a line out is not available, and voila!
    thanks kewlryds i might do that one of these days,
    and wildthing if i use a small 4 channel amp, will this be enough to power the 4 speakers even if my player is powered by a different source, like this scenario:
    self powered mp3 player line-out hooked to a small amp powered by the car's battery, then the 4 speakers are hooked up to the amp. will this work??? ganito siguro set-up ng motorcyles
    Feb 2004
    yup, that how it's basically done.
    Jan 2004
    Yep, as long as the four channel amp is matched to the speakers, I mean, it has enough power to drive the speakers. Hindi naman siguro malakas ang kailangan mo di ba so kahit 50Wx4 ok na, maliit lang yun.
    what type of connector will i use, dba sa mga mp3 players headphone jack lang? meron bang headphone jack at 1 end then RCA sa other end??
    Jan 2004
    Meron... but as usual, the output of these MP3 players are already amplified (maybe 4 watts). Baka merong mp3 player na may line out.
    I have not tried it but a 4W amplified signal fed into a line-level input might not be bad. Please correct me if I'm wrong here. If I am, then you will need a line-out converter.
    Feb 2004
    it's possible to use the headphone output of the mp3 player.
is there a smaller HU than 1 din???
