Results 1 to 15 of 15
    Feb 2004
    guys, i have an old school punch 200ix amp. this thing gives out a clean and steady 400 watts rms at 4 ohm bridged mono at 12.6 volts and 500 watts at 4 ohm bridged mono at 14.4 volts.
    this thing used to power a soundstream SPL 160 15" sub, so it is very strong and clean.
    what size and how many targa subs should i run off of this?
    i was thinking, maybe 4 10" subs, or 2 12" subs or 2 15" subs. what do you guys think?
    andy
    Mar 2004
    2 15" subs. pag 12" baka kaya nya yung 3 pcs. malupit lang tignan ang 4 na 10"
    Feb 2004
    siguro a pair of 15 inch subs na lang. Pajero naman ang kotse ko, so maraming space sa likod. tapos the box will be dual down firing, para stealth. the dual 15s will cost less, play lower, and move more air. mukhang dual 15 magiging decision ko
    May 2004
    ano b rms power nung 15s and their ohms?
    what kind of sound do you want?
    bayo!?gapang?
    or just the right "punch".
    the general rule is, the bigger the sub..the more gapang.
    the smaller...the punchier.
    id get the 2 12"'s.over kill na ang 2 15's kung hindi karin naman magpapabayo.
    4 10's?sayang sa space...
    Mar 2004
    pero kukuha ka din lang ng subs and kaya naman nung amp mo i suggest kunin mo na lang yung 15" compared dun sa 12". medyo nabitin ako sa 12" bumili din ako eventually nung 15" sayang lang sa pera. well its based on my experience.
    and mahirap mabitin
    as ive said, tingnan mo muna kung anong klaseng type of music ang gusto mo.
    i wouldnt want to use 15"s when i listen to patricia barbers, dianna krall and the likes...
    but i think mabibitin ako sa 12 inchers if im listening to BOOOM BOOM BOOOM all the time.
    and i don't believe that you have to use all of the amp's power....
    Feb 2004
    i will be using a 4 way setup, so my subs will be playing low frequencies lang talaga. maybe 70 hz down to 25 hz lang. i will be using a separate midbass from 80 to 200 hz and a 4 inch mid and tweeter component set to go from 200 hz and above.
    siguro with the crossover points set at those areas, my midbass can handle the punchier songs and the 15" subs can always be there in case i want to go boom boom. and the 12 inch can only play down to 30 hz, ang 15" goes down to 20 hz.
    any opinions on this?
    andy
    i dont think you can still hear below 30hz.....
    im more of sq kasi now thats why im leaning towards the smaller subs.
    to each his own.whatever suites you.=)
    Feb 2004
    i am definitely an SQL person pero i like having tailgate parties din kasi. hmmmm, interesting dilemma.
    any more opinions?
    andy
    auditioin muna kayo para alam niyo ung actual sound na maipoproduce nung mga yun.
    kung spl, dapat nagpunta kayo nung july 24 sa auto summit, pabayuhan talaga. ganda nung rav4 na red. 2 12" soloX! kaso basag na ung windshield sa sobrang lakas! anlufet talaga! best BOOM BOOM car ever heard
    Feb 2004
    holy crap, nabasag ang windsheild? he must have been powering those solo x's with over 1000 watts.
    actually, i just want to find the best bang for buck setup for my subwoofer amplifier kasi i don't intend to invest in amps na. match ko lang to what i have now which is 400 to 500 watts of raw clean old school rockford punch power.
    maybe i should consider a single 12 inch sub of a higher quality?
    andy
    May 2004
    1 12" will do kng pang listening quality lang like me City lang sa akin pero sometimes i listen to boombom pero di naman ako cocompete sa iasca[kasi la dito hehehe] so minsan naman pag may chicks kasama lovesongs diba and kng kasama nanay mga enya naman
    Jan 2003
    try mo comp vr na 15's kaya yan lakas pa......or yun targa 2 15's den yun box mo bandpass para sobrang lakas.
    Feb 2004
    i was really considering one 12 or 15 na comp VR tapos gawalang ako ng sealed and ported box and decide which of the 2 i like better. marami kasi akong MDF dito, ewan ko bakit, but i have two full sheets in the garage.
    andy
targa subs, what size to choose?
