Sa mahal ng mga branded na gamit na de kampanilya talaga bang mas maganda tumunog ang mas mahal? O may bigat din kung sino ang nag install?
Kasi meron nagsasabi mas maganda tumunog yung 50k budget niya kesa sa 100k budget na setup.
100,000 car system is not nessesarily sounds better than 50,000 car system its how you install it. System design strategy called IMAGING and STAGING is the key factor to obtain a better sound on your car. You dont have to buy all the expensive stuff to get the sounds you want. Any upgrade speakers can be shifted to suit and the sounds youre trying to achive and youll be surprise a cutting-edge that goes far beyond the easy fit concept.
Does this mean kahit puro targa from amps to seps to subs basta magaling nag install comparable to straight rockford set up.
it means that even if you buy expensive equipment, it could all go to waste with a bad install. but with the install as a constant, more expensive equipment would usually sound better.
well sometimes it does pay to buy the much expensive ones kasi may mga gamit naman talaga na maganda ang quality and with it comes a high price... pero hindi rin lagi... so sa huli, depende pa rin sa naginstall and how they installed your sound system...
Correct!
STEREO IMAGING and STAGING:
Now, lets talk about terms that describe a sound systems ability to correctly place the instruments of a band on an imaginary stage. Youre trying to create the illusion of a three-dimensional platform upon which the players are situated.
For example, a good recording are mixed for realistic staging, with the guitarist on right, for instance, and the keyboard player on the left. The lead vocalist is usually front and center, while the drum from the rear.
Reproducing the stage fell thats mixed into your CDs has nothing to do with the electronic component in your sound system and how the are adjusted. But its mainly a matter of the proper selection, placement and installation of your speakers. The stage should seem to be in front of your face, not behind your head or on the floor.
Try to envision what kind of work is going to be required to put the pieces where you want them. You can pick up on this stuff if your ear starts itching for more.
depende rin kasi minsan pangalan lang ang binabayaran mo, parang bumili ka ng sony xplode na napakamahal, pero mas maganda pa tumunog yung mga targa na dehadong mas mura kesa sa sony..![]()
