I came from Targa X series but i heard there are new budget seps out there sepcially in raon like LL and TEAC. Any feedback would be highly appreciated.
I suggest you stay with Targa until you save enough for decent entry level DLS or Morel or Focal speakers (budget around 10-12k).
Hi guys, with a budget of around 5k, what good seps can I get? I asked ACA and he suggested the nakamichi seps tapos deadening. Sa jetcar naman, DS18 black diamond. Do you have any other suggestions? TIA
I think 8k yung morel maximo. I really like it as i plan to install 1 as well. You can install it without an amp pero you'll need to install deadening sheet or acoustipad in ACA terms.
If budget lang talaga, yung nakamichi is good enough. Pero kung may storage ka naman for the stock speakers, i really suggest buying the morel then lipat nalang sa other car kapag ibebenta na.![]()
Morel is a known brand of car audio speakers. I know a lot of people will say it's good.
Current set-up.. Budget set-up lang ako but planning to set-up another car and doon ko itotodo yung set up ko.
Teac Seps
Sansui Coax
Lightning Lab amplifier running full range
1 sheet deadening per door
Dati naka-subs but removed it due to space constraints.
AFAIK, may 10k budget si jeff but you'll need to spend extra to deaden the doors. So set aside 15-18k maximum.
BTT: Hertz as mentioned by sientobente is also good based from feedback. It really depends on the budget kaya i would really suggest you to put a deadening sheet kasi malaki difference.![]()
That's a good start. Pero ako kasi inuna ko yung rear speakers with deadening sa front and back row then tska na ako nagpalagay ng seps. Teac seps, still very good after more than 6 months at 60-70% volume. Clear yung tweeter and yung midbass may kick naman. Subs, i had a "bazooka" sub but bypassed the internal amplifier but removed it after due to space constraints. Amp, yes big improvement kapag may amp. Nagugulat nga mga sumasakay kasi malinis yung sounds. Akala nga more than 10k yung seps.![]()
Interested ako sa 5k range na seps, Ano na ba price range ng cheapest morel and focal seps? thanks
